20 Most Recent
Archos Jukebox Recorder MP3 Player Questions & Answers
Lost my manul for archos jukebox recorder 20 mp3
Go to the RockBox software site. RockBox is provided freely by an end-user created and supported group and is a wonderfully evolved software replacement for quite a few portable music-playing machines. Your Archos Jukebox recorder is long out of warranty, so there's NO downside in updating it by installing the most current version of RockBox. That will greatly extend the capabilities of your machine.
Then download the RockBox user Manual! That will be your new Archos JukeBox Recorder User Manual. You'll be able to select what you hear by one of two control strategies: File names or by Playlists. You'll be able to adjust playback sound in new and more powerful ways than just using the equalizer. Also it will allow you to control playback "pitch" or speed, so you can hear lectures or books at a higher playback speed. Human retention actually improves when playback speed is increased some. You can print out the RockBox pdf. format manual if you'd like or you can study it on line. Lots of choices.
Good luck with your "obsolete" Archos JukeBox. I actually prefer the earlier models which were powered by four rechargeable AA cells rather than those with the replaceable lithium battery. I know someone who ran one of these continually for more than a year to provide background music, plugged into a wall-wart charger and his sound system. Durable!
John
Archos Jukebox...
Answered
on Feb 22, 2011
Archos Jukebox 10
The batteries put a lot of stress on some solder joints, causing them to break. Not charging is one symptom. Go to rockbox.com and look for detailed instructions on fixing it.
Archos Jukebox...
Answered
on Sep 04, 2008
Not enough free space
sounds like you are connecting your Archos to either a Mac or a Linux box. When you place items in trash they're actually placed in a hidden .trash folder on the Archos's internal drive and so still take up space.
Start by reconnecting the device to your computer and when it appears on your desktop try emptying your trash can/recycle bin, this will empty all .trash folders including the one on the Archos.
If you're using a Mac you may also want to use a 'clean eject' app such as
FinderCleaner to remove all the Apple system files from your Archos. Don't worry the only effect this has is to slow reconnection down by 1 or 2 seconds but it helps prevent problems like this and prevent the device from getting confused by Apple system files.
Archos Jukebox...
Answered
on May 09, 2008
Deleting files
If you've got it connected to your computer, you can do the same things that you would with any connected hard drive. In this case you should be able to delete files and then empty the recycle bin.
After that, go to My Computer and right click the icon for your Jukebox and select Properties. There you should be able to use Disk Cleanup to purge old system files, etc.
Archos Jukebox...
Answered
on Nov 08, 2007
