20 Most Recent
KitchenAid KTT340 2-Slice Toaster Questions & Answers
The lever button does not stay down,so the toaster
My toaster did the same thing. I cleaned the contacts on the mechanical switch with emery cloth and that problem was solved. Now I'm trying to figure out how to stop the breaker points on the mechanical switch from arcing - which I assume caused the problem in the first place.
11/24/2014 10:16:59 AM •
KitchenAid...
Answered
on Nov 24, 2014
I am trying to take apart the toaster, but...
You need to remove the four rubber feet at the four corners, and that's where the screws are. Get a small flathead screwdriver and pry the rubber feet out of their sockets and you'll see small screws.
I made some yummy waffles in my kitchen waffle
Unfortunately you have ruined a perfectly good waffle maker...
The coating in there is a teflon coating that needs to be applied properly for it to work...if you try to use it in the condition it is in then the waffle will stick to the plate...
Best thing to do is to trash the old one and then buy a new one...
heatman101
