20 Most Recent
Archos Gmini XS200 MP3 Player Questions & Answers
My Archos Gmini XS200 does not fully charge any
ebay have ads for replacements.
remove the back cover by taking out the 4 screws , fold out the hard drive unit and you will see the battery under it.
unsolder the two wires - positive and negative- ( red and black )
solder on the new battery wires in the correct place and re assemble unit .
Mp3 player not regonised
First of all, if you are attempting to plug this device in to the front usb port or to a usb hub, try plugging it directly in to one of the back usb plugs of your computer as this is going to be a true "usb 2.0" port. That is, of course, if your motherboard suports USB 2.0. As with most new devices, they are all usb 2.0 and only some will be usb 1.1 (the older version) compatible. As well, some usb players will have software that is not necessarily required to "see the unit" on the other hand, some do have device drivers that are required (as in the case of the toshiba and creative units), in order to utilize the built in software functions.
One other thing you can check for is the device manager (right click on MY COMPUTER and select PROPERTIES then click on HARDWARE tab and finally DEVICE MANAGER) Here you should see no "yellow" exclammation points which would be telling you of a device conflict. If you currently have your unit plugged in, you may notice the "unknown device" which would be your unit. By clicking on any item that has the exclamation and REMOVING it. Removing all devices with conflicts and then clicking on REFRESH (search for new devices) it should once again attempt to install the device. If you are still having troubles, I would be visiting the manufacturers website and reading any FREQUENTY ASKED QUESTIONS (faq's) regarding the device as well there are quite often updated device drivers available from the site in which you may or may not require.--------
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
Drive needs formating
WHEN UR DRIVE IS IN THE COMP AND USEE IT RIGHT CLICK IT SHHOULD =SAY FORMAT THIS DRIVE CLICK THERE AND FORMAT IT. AND MAKE SURE U HAVE AS A SLAVE NOT MASTER
Archos and radio
I use the cassette adaptor and run it through the tape player. I know most people have cd now, so this won't help.
Freezing
Im not sure how to put back in the strap but if you gotta loosen the cover or tighten it to get it to play theres a crackin the flex or main PCB.
Archos 605 wifi lcd screen keep turn off
If your Archos 605 WiFi LCD screen keeps turning off, it may be due to a few reasons:
- Battery issues: If the battery is low or has a poor connection, the LCD screen may turn off intermittently. Try charging the battery fully and checking if the problem persists.
- Power settings: The device may be set to turn off the LCD screen after a period of inactivity. Go to the device settings and adjust the power settings to keep the screen on.
- Firmware issues: If the firmware is outdated or corrupted, it may cause the LCD screen to turn off. Try updating the firmware to the latest version available.
- Hardware issues: If none of the above solutions work, it may be a hardware issue with the LCD screen or its connection. You may need to take it to a professional technician to diagnose and fix the problem.
I hope this helps!
