20 Most Recent Krups FLF2 Cordless Electric Kettle Questions & Answers
My Krups FLF2 kettle leaks at the bottom of the handle
This is a known issue with Krups kettles. If you are a handy person then you can remove the base and use a high temp gasket maker (auto shops have it) to add to existing silicone seal which goes bad after a couple of years.
1/16/2018 2:53:02 AM • Krups FLF2... • Answered on Jan 16, 2018
2answers
Krups kettle leaks at base of pot
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
1/16/2018 2:49:17 AM • Krups FLF2... • Answered on Jan 16, 2018
3answers
The kettle leaks at where teh handle attaches at
Join the club ---I'm taking ours back this afternoon to BB&B. It's still under warranty and we have the receipt.
5/10/2015 5:26:20 PM • Krups FLF2... • Answered on May 10, 2015
0answers
0answers
Krups electric kettle keeps shutting off
Buy a new one. Take the defective one, repack it in the old box and return it with the new receipt. Av a cup o tea.
12/18/2010 10:53:40 AM • Krups FLF2... • Answered on Dec 18, 2010
Power cord overheats
The thermostat is not shutting the unit down and cycling it on/off as it should. This will cause the power cord to overheat and it will catch fire. STOP using this unit and either replace it or have it repaired. More than likely cheaper to just replace it.
5/30/2010 2:58:58 PM • Krups FLF2... • Answered on May 30, 2010
0answers
tip
Krups Blender 577 replacement of rubber coupling
Krups Blender 577 - first try it not easy but next time it will be. Replacing the rubber coubling is extremely difficult with this model. After almost destroying the air in/outtake grill on the side in pursuit of a good lock of the axe, I tried so hard to use a nose plier to grab the post and unscrew the coupling counter-clockwise but it just didn't fit (it needs to be long and narrow/needle like). So I ended up cutting off rubber on the coupling and also cutting of plastic from the black plastic cover which is just under the rubber coupling. In the end I was able to cut that plastic and remove it so that I could actually take off the whole casing (you need a torx 20 with a hole in it to unsrew the 4 bits at the bottom underneath the rubber stands) with the rubber coupling still attached and detach two power cables so that I had much more space to properly grab the post and then it was very very easy to unscrew it counter-clockwise. But up until then I lost my insanity twice :-). Now I know how to so the next time will be easier.
KRUPS FOOD SLICER MODEL 213 HAS BEEN STORED FOR A COUPLE YEARS AND NOW THE BLADE WONT TURN. wHAT TO DO?
Thoroughly clean it then try a little bit of oil.
1/2/2018 7:24:28 PM • Krups Kitchen... • Answered on Jan 02, 2018
KRUPS KJ502D51 Stainless Steel Triple Basket Deep Fryer ********** Just bought used . Has error 2 on display
Here is the manual in case you do not have it:. Scroll down until you find "Documentation" and then download the instructions. http://www.krupsusa.com/KITCHEN-APPLIANCES/DEEP-FRYERS/4-5L-Deep-Fryer-with-3-Baskets-KJ502D51/p/8000035750 As far as the error code goes, Krups does not list anything. However, there is a reset button on this unit (see the manual), it may need deep cleaning, OR the internal battery needs to be replaced. If none of that works contact Krups (number inside the manual or on the website) customer support and see what they say.
12/7/2017 5:44:17 PM • Krups Kitchen... • Answered on Dec 07, 2017
0answers
Krups FLF2 Cordless Electric Kettle Logo
16 questions posted
Top Krups Kitchen Appliances - Others Experts
Mike
Narseman
Tom Chichester
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Krups Kitchen Appliances - Others
Most Popular Question
krups kettle leaks base pot
  • Kitchen Appliances - Others
