20 Most Recent Yamaha WaveForce 192XG Sound Card Questions & Answers
use the software provided by drp.su/downloads
Yamaha WaveForce... | Answered on Jan 26, 2014
Give this website a try for your driver
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
Yamaha WaveForce... | Answered on Jul 24, 2010
Hi ,
You can download driver for CS-4281 from the link http://www.zdnetasia.com/downloads/pc/swinfo/0,39043052,50002418r-39496284s,00.htm
I will try to send you link for Yamaha YMF 754-R soon
Yamaha WaveForce... | Answered on Sep 07, 2009
Here's the driver.
Download to desktop. When you update the driver, specify this location and your sound card should work after that.
Let me know/
Yamaha WaveForce... | Answered on Jul 17, 2009
That sounds alot like the microphone booster in control panel. Depending on what version of windows your are using, you can just open the sound control from the taskbar and go to the advanced settings and uncheck the setting "microphone booster". Adjust microhpone volume accordingly.
Yamaha WaveForce... | Answered on Dec 31, 2008
I would guess either the device is faulty, the USB port is faulty or there is a software glitch.
It used to happen to me a lot and it was usually a software problem - I can't prove it but I believe it was a conflict between the operating system and Nero, the cd burning programme.
Such things hardly happen since I stopped trying to use Nero. Software conflicts weren't unusual with low cost programmes which would "borrow" bits of Windows but fail to give them back when the programme was uninstalled.
The easiest way forward was to format the drive and reinstall the operating system.
Yamaha Computers... | Answered on Apr 19, 2020
it is not a computer, ok/? posted to computers.
its keyboard, Music and SUPER OLD NOW.
Yamaha SY77 is a 16 voice multitimbral music workstation first produced by Yamaha Corporation in 1989.
if you removed ROM from keyboard, that kills the keyboard dead.
you question is not clear, at all.
you need to talk to Yamaha, it is their keyboard.
Yamaha Computers... | Answered on Dec 05, 2019
So to confirm he connected power directly to the battery springs?
What voltage did he connect to those springs?
If it was more than 12v you have almost certainly done some internal damage.
As best you may have blown a few diodes which are there to protect from small voltage overruns - at worst probably burnt out the motherboard.
If you do not know how to check these it is probably advisable to take to a repair centre.
Becketts Music
www.beckettsmusic.co.uk
Yamaha Computers... | Answered on Aug 23, 2019
So what are you getting? Power light, screen display, just no sound?
Try pressing a demo tune - does that work?
If it does then you may have a problem with the connector from keybed to motherboard.
If no sound just try connecting the disc drive up again - if this then makes it work it is probably hanging during the start up procedure.
Report back if you need to and we can try something else.
Becketts Music
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
Yamaha Computers... | Answered on Jul 29, 2019
Guessing that some people think a Tyros 1 is a PC or something.
If the Tyros goes blank screen and all the lights go out then it is most likely the REG board (regulators) that provide the 5v and 3.3v. This overheats and the devices shutdown. Quite often this is cured with a restart on more serious cases the regulators need replacing. As they are cheep it is best to replace all while the unit is apart. I am just about to do this repair on a Tyros I purchased the other day.
Computers &... | Answered on Jul 27, 2019
Yamaha WaveForce 192XG Sound Card Logo
16 questions posted
Top Yamaha Computers & Internet Experts
Ekse
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Computers & Internet
Most Popular Question
want yamaha ymf754 r soudcard driver
  • Computers & Internet
