20 Most Recent Samsung Spinpoint MP4 HM640JJ 640GB 7200 RPM 16MB Cache 2.5' SATA 3.0Gb/s Internal Notebook Hard Dri... SATA II Hard Drive Questions & Answers
Hello, Run a HDD test from the BIOS and check could be bad clusters.
Samsung... • Answered on Jan 27, 2018
If the hard drive can't be detected by your computer, you can try this way.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezing sometimes works to revive a dying hard drive, at least for a short time(Probable just about 20 minutes), but be sure that the bag is sealed tightly so that condensation and ice crystals don't form. Put it in your freezer for 24 hours that will do the trick. While it's still cold, plug it into your computer.And you may be able to view it in 'my computer'.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data from hard drive with data recovery program.
Tenorshare data recovery is a professional data recovery program that can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
If it fails, you will have to go to a recovery office where supply data recovery service but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
Samsung... • Answered on Jan 21, 2013
viking_nm 26
Not sure if replacing the controller card will resolve your problem.
When you were doing the backup were you connecting the drive to your backup computer are you connecting it directly to the SATA port or via a USB connection.
Also do you have access to a Windows XP computer. I have found in several cases with mine own recoveries for my customers that if I hook the drives to my Windows XP computers the data is seen so I can recover it. It has to do with the fact that Windows XP handles the data differently than Windows 7/Vista does.
Let me know how things go and/or if you have any more questions
Issken
http://www.fixya.com/users/issken
Samsung... • Answered on Sep 21, 2011
To download songs just go to the website from where u want to download song then there should be download button around a song to download.Just click on it and your download starts.
thanx
Samsung... • Answered on Mar 31, 2021
1 Turn on the computer, then press the F4 key several times before the Samsung logo appears to open Samsung Recovery. 2 Click Computer Factory Reset 3 Click the Start Factory Reset button. 4 When the Start reset confirmation screen appears, click OK. 5 Your PC is reset. (Please note: resetting may take some time, depending on your PC.) 6 When a message appears saying reset is complete, click the OK button. 7 The PC will restart. 8 Finish setting up your PC according to the on-screen instructions. 9 After rebooting, check that your PC has been reset correctly.
Samsung... • Answered on Mar 27, 2021
Do you have a recovery CD or DVD that came with the unit? If so, try booting up from the cd and perhaps it will let you run a repair? Of if you can get into the BIOS of the unit, and that may be hard if your keyboard doesn't work, see if there's an option to activate the keyboard before bootup. Another idea is plug an external USB keyboard in and see if that works after a reboot.
Samsung... • Answered on Mar 08, 2021
check junk folder , check spam folder smart tv uses what system ? google android ? download app to tv from playstore if android system ??
Samsung... • Answered on Feb 12, 2021
Does this all-in-one have the original Windows 7 installed or has the OS been upgraded? This could be a driver issue or a problem with the Ethernet cable (if you are using the wired network). It could also be caused by the distance/direction between your computer and the router, if you are using the wireless network adapter. Try a new cable. Open the Device Manager (right click on Start for all versions of Windows). Find the section with the network adapters and check for entries with a yellow triangle with an exclamation point or red triangle with an x. These indicate the driver that has an issue. I recently went through some trouble-shooting on a slow computer running Windows 10 2004. After checking everything with the drivers, including launching the system in Safe Mode with Networking, I finally found the Blue Screen of ***** that the user didn't mention. The Windows Driver Verifier was causing crashes. The solution turned out to be using the sfc /scannow command at the command prompt when run as administrator. (Again, use right click on Start for a fast option to find the command prompt.) On one laptop (with OS updates from Windows Vista, Windows 7, 8, and 10) I dealt with, Microsoft installed a driver for the wireless network under Windows 10 that just didn't work. It would make the wireless network slower than the 10/100Mbs wired network adapter. Every time I did a clean install, I had to specifically install the correct Broadcomm driver for the wireless network adapter. I made a point to save this driver to a CD so that I could speed up restoring the network functions before Windows tried to do any updates. I hope this helps. Please add a comment with more information about the OS on the DP700A3B-A02US and the internet connection type that you are using. If you see any error messages or had any system crashes, add any key words that you saw. Then I can better assist you in solving the problem. Cindy Wells
Samsung... • Answered on Oct 20, 2020
Resolve the issue of Error Code 0xc0000185 with the help of the Hp Technical Support Phone number. Here the Technical Expert will provide you all possible help for getting out of this issue. Just visit the help website through the link shown below. Link:- https://www.hptechnicalsupportphonenumber.com/blog/fix-hp-printer-error-code-0xc0000185
Samsung... • Answered on Sep 11, 2020
there is a TP link that you can get from places like Jaycar that will turn your house wiring into extension cords for the router the operation can be explained at the shop but it means that you can extend the wires to any part of the house and by using ethernet cables will connect other computer, printers and tv units easily cheaper that new modems and routers
Samsung... • Answered on Jul 14, 2020
Well... Yes and No... Does this set have an Ethernet port? If so then try and plug it in that way. Try and reset the router and tv Make sure the connection settings are correct or defaulted Are you entering the correct password? Are you close enough to the router? reset the network setting on the tv it's possible you may have a bad wifi chip but im not thinking you do. Good Luck and come back it the above does not help we can go more into detail. Mr.Mike
Samsung... • Answered on May 20, 2020
Download and install this it will allow almost all media to play in your windows media player.
http://download.cnet.com/K-Lite-Codec-Pack-Full/3000-13632_4-64246.html?tag=mncol;2
Or you could download VLC media player, it plays everything.
http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html?tag=mncol;1
Personally I would stick with the windows media player, just because it's half a part of windows, & it's what I've always used. Or if you have a zune, or xbox windows media player is needed.
Samsung... • Answered on Apr 28, 2020
hi. my name is rui i will answer your question regarding your problem about how to setup a compatible dvd decoder for sumsung external dvd drive.
1st of what's the model of yoursumsung external dvd drive?
2nd if you have a internet connection and know the model of your dvd drive you can download a compatible decoder for your sumsung(model)using google.
here is one that you can try out its a NVIDIA PureVideo Decoder (NVIDIA DVD Decoder) 1.02.186 (Samsung Dvd Decoder).
NVIDIA PureVideo Decoder is a combination of a hardware video processor and video decode software for playback of DVD and MPEG-2 videos using Microsoft Windows Media Player and Windows Media Center Edition.
you can download it @ http://samsung-dvd-decoder.fyxm.net/
it's easy to use just follow the instruction...
hope it helps you in anyway.^_^
Samsung... • Answered on Apr 07, 2020
Samsung Spinpoint MP4 HM640JJ 640GB 7200 RPM 16MB Cache 2.5' SATA 3.0Gb/s Internal Notebook Hard Dri... SATA II Hard Drive Logo
3 questions posted
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Spinpoint Samsung
  • Spinpoint Samsung
Most Popular Question
samsung hm640jj
  • Computers & Internet
