20 Most Recent Bang and Olufsen Beosound 2000 Shelf System Questions & Answers
0answers
0answers
Bang and olufsen beosound 3000 does not read cd and loading stops. Can you help? Thanks
I never had like that. But "normally" there may be two reasons: CD fault or control board fault. Sometime main control keeps memorized wrong data and (in my Ouverture) CD unit simply is not responding and not loading - standing still. No way to move on except plugging off the power, press CD start on remote with no power, plug in power and try again. It clears bad data. I suspect it happened few times when I stopped CD player by remote or local main switch off.
12/27/2014 2:10:47 PM • Bang and Olufsen... • Answered on Dec 27, 2014
0answers
0answers
Oubverture 2500 disassembly
remove the glass doors and the two black glossy covers first
7/2/2014 10:37:53 PM • Bang and Olufsen... • Answered on Jul 02, 2014
How do I change Bang & Olufsen Beosound 2000 door belt?
I just did that ; took an 031 oring or was it an 032; and you have to pull the whole drive mech out; it is tricky and if your not small mech inclined don\'t do it; There is a few gears and they work in tandem so when you put it back together it has to be just right; if you take it out take pictures of it as you take it apart because you will never remember how it goes back together; easy to get out; a pain to put back together. And it will all come apart just to put that oring in.
5/6/2014 8:38:19 PM • Bang and Olufsen... • Answered on May 06, 2014
Beosystem
first what is the error if its no disk first clean optical lens dust in upper layer, then check motor its carbon brush motor replace it, then check strip cable remove then clean the track then plug in.
4/28/2014 6:40:39 AM • Bang and Olufsen... • Answered on Apr 28, 2014
0answers
I have a beosound century and whenever the glass
This mechanism has overload coupling inside. When mechanical overload occurs the coupling may klick. Else doors are jamming so coupling is set too low. Check doors and if they are easy look at coupling - it has spring and screw adlustment at center of linkage drive whell.. I don't know Your model but in Ouverture it is easy to reach. But don't try if you are not experienced (You didn't damage minimum 10 sets in life :).
2/21/2013 11:24:53 AM • Bang and Olufsen... • Answered on Feb 21, 2013
2answers
B&o sound system not working
try buying an ordinary cd lense cleaning (CD), if you are brave you can try adjustind the pick up of the laser on the laser board pot inside the cd player. it might just need a service
11/15/2012 9:34:25 PM • Bang and Olufsen... • Answered on Nov 15, 2012
0answers
BeoSound 8
Be the first to answer 10/21/2012 4:02:28 AM • Bang and Olufsen... • Posted on Oct 21, 2012Be the first to answer
Popular Tags
77 questions posted
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bang and Olufsen Audio Players & Recorders
Most Popular Question
bang olufsen beosound 3000 not read cd
  • Audio Players & Recorders
