20 Most Recent Oreck Console Air Purifier Questions & Answers
I tried that solution and it did not work due to the worn bushing. I went on line to CSH incorporated and ordered #534 Open Ventilation Fan & Blower Duty motor. The motor is a ball bearing motor rather than bushing, and is an exact replacement for the Fasco motor on the original. The repair is easy and a cheap repair at cost of about $67 dollars for the motor plus shipping. The unit now works great again.
Robert
Oreck Console... | Answered on Jan 31, 2016
It sounds like the calibration of the flux capacitor is not properly configured and is not in sync with the intercooler. Your Oreck XL won't function properly until you manually open the exhaust hatch, remove the nuclear power cell and replace the plasma coils. It also would help to wipe off the air filter with a rag.
Oreck Console... | Answered on Aug 17, 2014
I also have an Oreck Console Air Purifier a260. Like Moojenblue wrote on Oct 3, 2010, I cannot find replacement filters either. Thank you to anyone that may be of help. Mary Jo
Oreck Console... | Answered on Oct 13, 2012
problem solved
thank you
Oreck Console... | Answered on Nov 06, 2009
Soak the filter in soapy water overnight
Oreck Air... | Answered on Dec 17, 2019
Depending on what model , when my red light comes on and flashes it usually has something stuck in the cell it can be real small even or lots of build up on cells, when you pull out the cell you can determine if the wires are broken.
Oreck Air... | Answered on May 05, 2018
I'd give oreck a call...
To speak with an Oreck representative call:
USA: 1•800•989•3535
Canada: 1•888•676•7325
Oreck Air... | Answered on Apr 07, 2018
you have to check OM. Usually you'd have tu push something 10 times to reset
Oreck Air... | Answered on Jan 22, 2018
They discontinued it. Just go to any aquarium and buy a carbon filter pad and cut it to size. They sell big sizes for under $10 and just stick it in your Oreck Air 5 air purifier. Works just as well and cheaper!!
Oreck Air... | Answered on Sep 06, 2017
I would look at the board using a high powered magnifying glass to see if there was any signs of broken stubs of wires sticking out of any solder joints. Also look for solder joints that have no other possible routes, (dead ends) that do not have any other connections running from them. Like a resistor that has a copper path on one end and nothing running from the other end. Or it could be a ground wire if no other spot is found.
Oreck Air... | Answered on Nov 06, 2015
screws on the bottom need to be removed it separates in 2 pieces
Oreck Console Air Purifier Logo
Popular Tags
10 questions posted
Top Oreck Air Purifiers Experts
Marvin
Marvin
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
Oreck Air Purifiers
  • Oreck Air Purifiers
Most Popular Question
oreck air purifier model air 4000
  • Air Purifiers
