20 Most Recent Krups XP7245 Questions & Answers
The sensor is not detecting any heat from the boiler element. Most common cause is the sensor has become unstuck from the front of the boiler. Second most common cause is solder failure and wire is no longer making contact. If you cannot fix it then you need to buy a new boiler so be very careful and make no mistakes about how you plan to fix it.
Krups XP7245 | Answered on Feb 28, 2014
Look for a water leak, it may be to the base of the machine and will release out the vent UNDER the drip tray if you tilt the machine forwards. There are many places for it to leak, not easy to find, I have an outer housing with cutouts to allow me to see inside while it's running. Hydraulic ram and the distributor are the most common places to cause error 6 but there is also a tricky one where the valve on the pump releases to the drip tray. A leak is the problem, finding where/which is the hard part.
Krups XP7245 | Answered on Dec 02, 2013
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Krups XP7245 | Answered on Oct 23, 2012
Krups XP 4020 Semi-automatic Espresso Coffee Maker http://www.coffeemachinemanual.com/krups-xp-4020
Krups XP Coffee... | Answered on May 26, 2016
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Krups XP Coffee... | Answered on Jan 28, 2016
Check the water float in the tank, it is common for them to cease floating sometimes. Krups solution is a new tank, my solution is to jam something plastic underneath it to lift it up so that it activates the sensor. Even if tank is empty it will no longer ask you to fill it up.
Krups XP Coffee... | Answered on Feb 06, 2015
I don't think there is a lot you can be doing wrong to cause that apart from maybe something not too well cleaned and creating a restriction for the steam.
You will need an instruction manual, if you leave your email address I will send it as a PDF file.
Krups XP Coffee... | Answered on Dec 08, 2014
Open the machine up and look for a broken hose or similar.
Krups XP Coffee... | Answered on Oct 02, 2014
Krups XP7245 Logo
21 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Ross Keen
ThaMp3Doctor
ThaMp3Doctor
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
XP Krups
  • XP Krups
Most Popular Question
error 06
  • Coffee Makers & Espresso Machines
