20 Most Recent
ILuv i1277 Theater System Questions & Answers
I have an iluv i1277
Hi there graham,
Please make sure that you have put the speakers into the correct ports on the back of the home theater. usually it's labeled W or SW for the subwoofer, FR and FL for the front left and right and RR and RL for the rear right and left.
Now if that does not work still then you would want to check the wires going into the speaker and make sure that it's plugged in all the way on both ends and you may have to splice the wire and make sure that the copper is reaching the inside of the port on the back of the speaker.
If you've already checked that and the sound is not working then there's a problem with the board where the speaker ports are and that would have to be repaired.
Hope this helps!
Why my nabi2 pear with my iluv speaker but can't hear it ?
Pairing and connecting are different steps in the process of connecting two Bluetooth devices. As long as your headphones are not CONNECTED (not just PAIRED) with your tablet, you are not going to hear anything that you play on the tablet (music, video, etc.).
The sound is coming out
Then you need to adjust the earphones plug in, adjust it gently and it will sound right on both earphone. It is the plug that is causing the problem. Adjusting it will solve the problem for you.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
