20 Most Recent Marantz SR7005 Receiver Questions & Answers
I have a Marantz sr7005. The video has started to cut out, usually in the morning when first fired up.I can then turn it off and then back on again and it will start the video again. I may have to d
I have an SR7005 that has a problem with no more video coming out (blank screen), but the sound works perfectly. Does anyone know of a company or person that repairs the board?
5/24/2022 3:13:08 PM • Marantz SR7005... • Answered on May 24, 2022
Hi, I have recently purchased
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
6/12/2017 4:34:51 PM • Marantz SR7005... • Answered on Jun 12, 2017
2answers
I just installed a 7005
HelloThe power amplifier section of your Marantz has damaged. There is a possibility that the speakers that was connected to thes amp sections alos may have got damged. If you want to repair it by yoursef, you need its service book; not the user manual. Service book contains all the details about its repair, parts names, locations, printed circuit boards and its schematics, wiring diagram etc:- I've it with me now, but I can't send it to you by this window as this window does not allow me to upload PDF files by it. The repair book contains 205 pages and comes upto 23MB capacity.If you are interested you must have to buy one among my advertised audio services at Fixya, and send your email address by that window, so taht I can send you both the user manual and repair book of the same as seperate uploads. OK.
12/18/2016 7:57:39 AM • Marantz SR7005... • Answered on Dec 18, 2016
2answers
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
9/2/2016 9:07:50 PM • Marantz SR7005... • Answered on Sep 02, 2016
No image, only sound when
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
12/8/2013 10:45:50 AM • Marantz SR7005... • Answered on Dec 08, 2013
My sr 7005 loses a
It takes two, maybe more to tango - plus the cables that carry the various signals.
Can you define the signal loss better? Where do you detect it?
Audio, video, both?
Optical, HDMI, component ????
Try a different input or output port on the Marantz to isolate the source(s) as contributors.
6/10/2013 8:17:54 PM • Marantz SR7005... • Answered on Jun 10, 2013
Recently purchased Marantz SR7005, all
HelloGo its user manaul page [76 & 77]. You can understand what Audyssey is. Make it OFF. Proceedings are there one these pages. OK.
1/8/2012 2:23:19 PM • Marantz SR7005... • Answered on Jan 08, 2012
It's impossible to stop the
HelloYou must have its repair book, not the user manual, with you to know all about the firmware update and other things. There are so many adjustments should be done after firmware update, and all of them cannot be snd to you by this window, ad they contains illustrations.If you are interested to get a copy of the repair book, you have to muy one amomg my audio services advertised at Fixya. Send your email address by that window, so that I can upload both the user manual and repair book to you by return mail. Both of the together will come over 35MB. OK.
1/8/2012 11:46:56 AM • Marantz SR7005... • Answered on Jan 08, 2012
Need PDF User Guide
HelloSend your email address to me by Fixya comment. I've the user manual to your device in PDF format. I'll send a copy of it to you by return mail. OK.
1/8/2012 11:42:53 AM • Marantz SR7005... • Answered on Jan 08, 2012
Upgrade id disappeared
HelloAll these details are in its repair book. There are so many adjustments should be done, and all are described in detail in that book. I've the book, but aI can't send it to you by this window as it does not allow ma to upload PDF files by it. If you come over me by purchasing any one among the audio services advertised at Fixya, I'll send you both the user manual and repair book to you by return mail. The repair book is very usefull to you as it contains all the internal circuit details, schematics, possible repair and its remedies. OK.
1/8/2012 11:34:53 AM • Marantz SR7005... • Answered on Jan 08, 2012
How do you reset a marantz
HelloAll details about reset and other functions and adjustments are with its repair book. I've the repair book, but I can't send it to you by this window as this window does not allow me to upload PDF files by it. The book is in PDF format, having 205 pages and have 20.5MB in capacity.If you are interested to get it, you have to buy one among my audio services published at Fixya, and by send your email address to me by that window. You ac also access my services by searching at Google. Tyep in 'gopakumar gopalan - profile - fixya' at Google search baox and press enter. Click the link and you can see all of my services advertised at Fixya there. Choose an appropriate one among them and send your email address to me by the window appears. I'll send you both the user manual and repair book to you by return mail. OK.
1/8/2012 11:28:31 AM • Marantz SR7005... • Answered on Jan 08, 2012
Hi There, I have a
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
7/7/2011 10:29:16 AM • Marantz SR7005... • Answered on Jul 07, 2011
3answers
My ipod gen 4 does
hi there,
Have you already downloaded the Marantz wiz app?
the wiz app is free to download from the App store.
Try downloading that first and check if it will let you do the full control.
Thanks!
6/3/2011 4:55:25 PM • Marantz SR7005... • Answered on Jun 03, 2011
Is the Marantz SR68 an FM tuner please?
No, it is a Surround Sound Receiver for taking television signal, or a signal from another device and amplifying it to multiple speakers.. https://www.google.com/search?q=Marantz+SR+68 ..
2/21/2023 4:20:06 AM • Marantz Audio... • Answered on Feb 21, 2023
HI, would you know what error code CY920 on my Marantz NR1607 means ?
The Marantz NR1607 is an AV Receiver, and the CY920 error code is not a recognized error code for this product. It's possible that this is a custom or specific error code for your device, and I would recommend contacting Marantz support or the manufacturer for more information. They may be able to provide you with a solution or more information on what the error code specifically means and how to resolve it.
2/12/2023 3:15:35 PM • Marantz Audio... • Answered on Feb 12, 2023
Marantz SR7005 Receiver Logo
26 questions posted
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Audio Players & Recorders
Most Popular Question
marantz sr7005 video started cut out
  • Audio Players & Recorders
