20 Most Recent Integra DTR-5.1 Receiver Questions & Answers
You most likely have a power amp problem, disconnect all speakers and see if still does the clicking, if so you have an output amp problem
Integra DTR-5.1... | Answered on Feb 25, 2015
is it set properly for that input? does it play on the tuner setting? check the connecting cable for breaks..
Integra DTR-5.1... | Answered on Feb 02, 2014
Hello
Sony RM-AV3100 remote has no codes to setup with any Integra devices. You have to try its code search method. Sometimes you may find a code. But not sure. Go to the user manaul of that remote. There is proceedings for code search process. The codes are four digits indeed. OK.
Integra DTR-5.1... | Answered on Oct 16, 2011
It may not take the iPod directly if it doesn't have a dock built in, but you can always connect the iPod to an available input with a suitable cable. You'll need a cable with a plug to fit the iPod headphone jack (a 1/8-inch stereo plug) at one end, and probably RCA plugs at the receiver end. Radio Shack sells one so you can see what you're looking for. If you have an iPod dock, they often have audio output jacks for connecting to your receiver. You may need a cable with RCA plugs on both ends.
Integra DTR-5.1... | Answered on Aug 07, 2011
I have the same problem! Could you fix it
Integra DTR-5.1... | Answered on Feb 12, 2011
surround speakers work only when you put 5.1 ch recorded dvd in it
Integra DTR-5.1... | Answered on Jun 04, 2010
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Integra DTR-5.1... | Answered on Mar 07, 2010
You may have an over heating problem as it the Integra has anautomatic cut out. The unit generates a huge amount of heat and needs to be positioned in a very well ventilated position.
Linian
Integra DTR-5.1... | Answered on Mar 26, 2008
http://www.integrahometheater.com/faqs.php Check the connections and try a master reset?
Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode.
Integra Audio... | Answered on Jul 03, 2018
Integra DTR-5.1 Receiver Logo
18 questions posted
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Integra Audio Players & Recorders
Most Popular Question
will receiver accomodate ipod
  • Audio Players & Recorders
