20 Most Recent Tokina 12-24mm f/4 Pro DX for Nikon Questions & Answers
Manual Tokina 70-210
Where are the details ?? You did not mention the problem you are facing.
7/18/2013 9:53:24 AM • Tokina 12-24mm... • Answered on Jul 18, 2013
Over exposure in cold weather
I suggest that you contact Tokina directly to find out what range of temperatures your lens is designed to work across.
Your expression "cold weather" is an imprecise term; where I am in the UK means at worst down to a few degrees below freezing and usually a bit above, but when I'm in Moscow they don't consider it to be cold until the temperature drops to around minus twenty-five Celsius.
Depending on where you are, your lens may simply be unable to cope with what you describe as cold weather but you won't know until you have the specifications from Tokina. If it turns out that your lens is not performing as intended, then the manufacturer will be able to suggest remedies to you.
Sorry I cannot be more specific but Tokina do not appear to have published the range of operating temperatures in the public domain.
3/2/2010 11:30:13 PM • Tokina 12-24mm... • Answered on Mar 02, 2010
I just bought the Tokina SD 12-24 F4 (IF) DX
Only the MkII version of this lens has an autofocus motor built in, the MkI relies on a motor in the body of some Nikon AF SLRs to autofocus. The D70 does not have an inbuilt AF drive motor, so if you have the MkI lens then you can only use it in manual focus mode on your camera.
8/5/2009 2:30:54 PM • Tokina 12-24mm... • Answered on Aug 05, 2009
2answers
Lens hood BH-777
If such a thing exists, it would be on eBay or Froogle. However, that is so wide, I doubt a lens hood exists for it, as it would cause a lot of vignetting.
3/2/2009 9:40:32 PM • Tokina 12-24mm... • Answered on Mar 02, 2009
Does Tokina-12-24mmF/4Pro DX complies with Nikon-D3 FX Format
Barrel distortion like you describe can always be a problem, especially at ultra-wide focal lengths like yours at 12mm. Some of this can be compensated for in software... Adobe Photoshop CS2 and Elements do a reasonable job, IMO, Bibble Pro (www.bibblelabs.com) does even better, especially with the 3rd party plugins like Percy perspective correction. These are things we have to live with when we have smaller sensors and ultra-wide angle lenses. There is nothing wrong with your lens, you will probably find that this distortion is minimized if you use a longer focal length (say 14mm) and/or stop down the lens a bit.. try f8, wide angle lenses have huge depth of field.
5/20/2008 9:28:57 AM • Tokina 12-24mm... • Answered on May 20, 2008
Tokina Lens hood BH 779
B&H Photo/NYC has them in stock: B and H
1/24/2008 2:04:43 PM • Tokina 12-24mm... • Answered on Jan 24, 2008
Tokina AF 80-400mm f/4.5-5.6 owners manual
What about it, and why do you want it ? It is simplicity itself - attach the lens to the camera, switch on the camera, frame the subject and shoot.
8/29/2017 8:22:17 AM • Tokina Cameras • Answered on Aug 29, 2017
How can I disassemble Tokina 80-400mm AT-X Af Lens for cleaning haze from elements
THIS IS NOT POSSIBLE WITHOUT SPECIAL TRAINING AND TOOLS. SEND TO AUTH SERVICE CENTER OR REPLACE.
7/3/2016 2:43:21 AM • Tokina Cameras • Answered on Jul 03, 2016
2answers
I have a Nikon D90 and I purchased a Tokina AT-X 24-200 a couple of weeks ago and the combo has been working great. However, today when i went to take some photos the shutter release would not work. U
What does the FEE or error message displayed on an SLR camera mean... The link is to a Nikon error page which explains what could cause this error. Is the lens set to the smallest aperture? If not this would cause this error.
10/22/2014 3:27:28 PM • Tokina Cameras • Answered on Oct 22, 2014
0answers
0answers
0answers
0answers
0answers
2answers
I have a tokina 500mm f8 lens with a P/K mount
This will depend on the lens you have now.
Some Tokina lenses have a universal fitting, with a separate adaptor mount for each camera body they fit. Its usually the last 5 - 10mm of the mount, and its identifiable by a second release button, which allows the specific fitting to be changed. If you have one of those, you just need the Nikon fitting.
If the P/K mount is an integral part of the lens, you have a couple of choices.
(1) You could get an engineering shop to alter the mount. This costs a lot and probably isn't worth the hassle. (It might be better to sell your lens and buy the nikon equivalent).
(2) You could use an adaptor. These are readily available on eBay.
For example:
http://cgi.ebay.co.uk/Pentax-PK-K-Lens-to-Nikon-AI-AF-F-camera-mount-Adapter_W0QQitemZ150400359906QQcmdZViewItemQQptZUK_Photography_CameraLenses_Lens_caps_hoods_adaptors_ET?hash=item23048f5de2
Note that just because it has the right (i.e. Nikon) fitting, it doesn't mean that it will necessarily have full functionality on the body you intend to use with it.
Some Nikon bodies are "extremely fussy" about which lenses they can use, and it might be worth evaluating whether your proposed solution would work with the camera body you have in mind before committing to any sort of expenditure.
9/24/2012 5:40:55 PM • Tokina Cameras • Answered on Sep 24, 2012
0answers
Tokina 12-24mm f/4 Pro DX for Nikon Logo
11 questions posted
Top Tokina Cameras Experts
Steve
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Tokina Camera Expert? Answer questions, earn points and help others
View Most Popular
Tokina Cameras
  • Tokina Cameras
Most Popular Question
over exposure in cold weather
  • Cameras
