20 Most Recent Hino 2006 268 Questions & Answers
The clutch plate is probably stuck. If you have a clear space in front of the truck select first gear, release the parking brake and start the engine with your foot on the clutch. The vehicle will lerch forward and the engine should start with the vehicle now moving forward. Hit the brakes with your left foot still on the clutch and the clutch will probably release and work normally.
Hino 2006 268 | Answered on Jan 15, 2019
that could be dependent on the engine. BUT, since you didn't tell anyone, it is impossible to give you a concise answer. anyway, once you decide what engine, look it up yourself on the internet rather than take someone's word for it.
setting that clearance adjustment could be really important for engine life.
Hino 2006 268 | Answered on Oct 19, 2018
Hiya,
When your painting iron its all about the primer, this helps its withstand the elements. Make sure you
also remove any existing rust! Here is a good example of how to paint a iron fence. Let me know if you have any questions
Home Fencing | Answered on Aug 25, 2020
The timing relay has to be setted right.
There is a time control on every unit,.
1-[Distance has to be set right before setting time relay]
2-(opening time and closing time has to be set accordingly to ur safety and wanting)
Home Fencing | Answered on Mar 27, 2019
Do you have sensors that stop the gate closing on people or cars ? If so put your ear near the sensor but not inline with the opposite one. Now gently wave your hand in front of it .... if there is no click then something is obstructing the beam. Sometimes spiders get inside and spin that candy floss type web in there .
Home Fencing | Answered on Mar 18, 2019
The first place to look is your receiver. This is the device, often separate from the actual gate operator, that responds to your transmitter. Stand next to the gate operator and you should hear a small click coming from the receiver when you or someone else pushes the button.
You can sometimes find the receiver by following the antenna cable back to it. If it does not have an external antenna, look inside the operator box for either an antenna screwed into the receiver or a wire hanging from a plastic box.
If you hear the click and the gate does not open, the possibilities grow exponentially so we won't try to address every possibility here. If you hear a click when you are close, but not when the transmitter is triggered at a distance, check the antenna.
If you don't hear the click, then either the remote has lost programming (this often happens with rolling codes transmitters when they are not used for a long time), or the receiver is not working.
Check to make sure the receiver is getting plenty of power power using a meter. It should read at the recommended voltage or a bit higher. Usually around 24 volts but some receivers can work down to 12 volts. If it gets plenty of power and the remotes have been programmed back in, consider replacing the receiver.
Home Fencing | Answered on Mar 08, 2019
remington model 476 power nailer
Home Fencing | Answered on Oct 19, 2018
you can find one via the internet. doh.
what about them ?
I think you should hire a competent electrician. your question indicates you aren't qualified or competent to work on electric power, and it could cause a fire.
look it up on the internet and get the right answer, complete and fully described.
Hino 2006 268 Logo
9 questions posted
Top Hino Home Fencing Experts
Tom Chichester
 Russ Hill
Russ Hill
ray gallant
Are you a Hino Home Fencing Expert? Answer questions, earn points and help others
View Most Popular
Hino Home Fencing
  • Hino Home Fencing
Most Popular Question
hino 2011 300 series tipper parked three
  • Home Fencing
