20 Most Recent Kicker Comp CVR 12 x 12 Car Subwoofer Questions & Answers
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
2/20/2015 8:52:18 AM • Kicker Comp CVR... • Answered on Feb 20, 2015
How do you take the cvr kicker apart
are you sure that you are capable of replacing the rubber ring if you don't even know how to take the speaker apart? I am Not sure that that's a challenge you want to accept.
11/21/2014 4:44:28 PM • Kicker Comp CVR... • Answered on Nov 21, 2014
2answers
2 kicker cvr 12's in prewired kicker box with 1
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
11/21/2014 4:42:30 PM • Kicker Comp CVR... • Answered on Nov 21, 2014
How do I replace the wire that's connected to the sub?
Just go to an electronics store or Walmart and buy some wire.
9/14/2014 10:54:16 PM • Kicker Comp CVR... • Answered on Sep 14, 2014
0answers
My dual 2 ohm cvr12 kicker are burning on the red dot Connection what can it be and also the symtem hits fine for min then fade.
check that you have the correct impeedance polarity try turning down your amp gain most of the time its wattage match get as close of a match as possable ohms must be corect for amps specs
11/28/2012 11:49:12 PM • Kicker Comp CVR... • Answered on Nov 28, 2012
Why is my Kicker dxa 120 5.2 protection light and power light on at the same time and not putting out any audio
Your Kicker has gone into protect mode and will stay that way until the component level problem is found and fixed.
9/6/2021 5:41:46 AM • Kicker Car Audio... • Answered on Sep 06, 2021
Brand new Kicker 46CXA8001T amp and Skar 12" sub DVC 4 Ohm wont work
limited information generic answer -notify kicker customer assistance and will need to let them know what vehicle
6/24/2021 8:47:23 PM • Kicker Car Audio... • Answered on Jun 24, 2021
Reset lock code for 650.1 kicker amp
Here is your answer: https://www.fixya.com/support/t10052958-sx650_1_kicker_locked
10/4/2020 7:44:15 AM • Kicker Car Audio... • Answered on Oct 04, 2020
Kicker pt250 light is on blue, but there is no sound. It used to sound perfectly, but now it will work sometimes. Generally when it has been off for a while.
Hi Hector, if all the wiring is connected properly, you then mite have a problem on the circuit board, or with the subwoofer itself. While its switched off try moving the switches one or two times just in case there is a dry contact. Next would be to take in the unit for an independant bench test before opening the unit. Cheers.
4/4/2020 9:58:25 PM • Kicker Car Audio... • Answered on Apr 04, 2020
2answers
Is there a way to fix a kicker solobaric L7 dual coil 15' sub if one side is reading bad on a multimeter?
About all you can do if your really wanting to "fix" it, is tear it apart & completely recoil both voice coils.
Otherwise you can just run it on the one good side like a single voice coil sub.
10/8/2019 3:13:13 PM • Kicker Car Audio... • Answered on Oct 08, 2019
Where is the ground wire location in the kicker kq9 equalizer
It belongs in the 4 port molex that has the RED, Blue Blue/white and last wire should be black
7/24/2019 9:10:40 AM • Kicker Car Audio... • Answered on Jul 24, 2019
What size box will give me the best sound for a 10" Kicker C 104?
If going sealed I would aim somewhere in the 1.5 to 2.0cuft area. That sub can go in a 1.0 cu ft box to 2.4 depending on the room you he the bigger is usually better for sound quality
4/26/2019 10:26:35 PM • Kicker Car Audio... • Answered on Apr 26, 2019
Ineed help with wiring a kicker 10in comp sub to a razor RZR1-2500D amp i cant get it tuned
First, that amp, has too much power for that sub. Even though it isn't really outputting 2500 watts, (realistically putting out 650 watts). That sub is only rated to handle 150 RMS, 300 Peak, 1000 watts will blow that sub very quickly.
First thing you need to do is find a sub which better matches the output of your amp.
The second thing, you need to make sure that your vehicle's electrical system is able to handle the additional current draw.
Address these things before you install your gear.
I've been a 12v installer for going on 28 years
2/10/2019 7:03:44 AM • Kicker Car Audio... • Answered on Feb 10, 2019
Kicker Comp CVR 12 x 12 Car Subwoofer Logo
8 questions posted
Top Kicker Car Audio & Video Experts
Morne Olivier
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Oloyede Monsuru
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kicker Car Audio & Video
Most Popular Question
replace wire amp 39 s connected sub
  • Car Audio & Video
