20 Most Recent
Toshiba Satellite L455DS5976 Questions & Answers
Can only certain alpha keys
I would try cleaning your keyboard. If you are gentle you can remove the F10 key and check that they is no dirt underneath. Check other keys near the F10 key in case others have the same problem. I know that a sugary Cola spillage on a keyboard really sticks things up. In that case it was easiest to get a new keyboard.
5/21/2014 9:52:08 PM •
Toshiba...
Answered
on May 21, 2014
How can i get the specs for hl-dt-st dvdram gt20n
It's an ATA device. (ATA / IDE)At MAXIMUM:A) It can play back DVD's at 8X speed,B) Read CD's at 24X speed,AND Write,1) CD-R's at 24X speed.2) CD-R/W's at 4X speed.3) US CD-R/W at 24X speed.4) High Speed CD-R/W at 10X speed.5) DVD-R at 8X speed.6) DVD-R/W at 6X speed.7) DVD-R+ at 8X speed.8) DVD-R Double Layer at 6X speed.9) DVD-R/W+ at 8X speed.The optical drive in a Toshiba Satellite L455D-S5976 Notebook PC, is a DVD Super-Multi drive, that is capable of using disks that are Double Layer, and R- or R+In all actuality about what is the best burning speed, it is the Slowest speed that you can choose.That is usually 4X.However I would recommend 8X in all situations.Makes a better burn, and is easily readable by other optical drives.Makes it simple, huh?For additional questions please post in a Comment.Regards,joecoolvette
1/11/2012 11:28:30 PM •
Toshiba...
Answered
on Jan 11, 2012
Manual Toshiba L455D-S5976
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2428387/GMAD00220011_SatL450_09Aug21.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
11/29/2011 4:19:17 PM •
Toshiba...
Answered
on Nov 29, 2011
My fan doesnt seem to be working and laptop just
Hi, your laptop shuts down as a protection against overheating. It's important that you take the laptop right away to a service repair shop so it can get the fan replaced before other important components get damaged.
7/27/2011 10:23:56 AM •
Toshiba...
Answered
on Jul 27, 2011
During use the screen went
hi there,
You can try to:
- unplug the computer from the power outlet
- remove the battery
- press and hold the power button for 20 sec then try turning the computer on
If it still does not work:
- on the back of the computer remove the cover for the memory modules, then take off the memory sticks
- use a pencil eraser and rub the metal contacts of the memory sticks
- put them back in, close the cover and plug the computer to the power outlet without the battery
Hope this helps!
6/25/2011 2:28:53 PM •
Toshiba...
Answered
on Jun 25, 2011
My mouse pointer not moving
Try to press Fn (locate at the bottom left of the keyboard near CTRL )and at the same time tap F9 (on top of the keyboard), you will see the status if it's enabled or disabled, just tap F9 to make it enabled.
2/24/2011 3:05:54 AM •
Toshiba...
Answered
on Feb 24, 2011
Fan used to run all
check the fan. use manual guide to open the cover with extra care too.
2/11/2011 2:06:20 AM •
Toshiba...
Answered
on Feb 11, 2011
Windows media center has taken over under one sign
I believe the media center has been configured as your default application to launch your programs. You could click on start button and got to default programs. from there click on auto play settings. you'll have an option there to select w/c software you want to use or run.
Good luck
Ryan
1/9/2011 3:22:30 AM •
Toshiba...
Answered
on Jan 09, 2011
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
