20 Most Recent Philips GoGear SA2RGA MP3 Player Questions & Answers
Downloading Music to MP3 Player
Hi london 42
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11.
If this happens to you then you will have to unistall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Windows Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your data cord.
6...Media Player should recognize the MP3 player and sync with it.
7...After it is synced with the computer,you can add the music you have installed in Media Player to your MP3 Player.
Free Answer...Please take time to rate me
Philips GoGear... | Answered on Mar 16, 2012
Manually breaking the power connection should resolve the issue.
This is what I did when my GoGear VIBE 4GB froze up:
Carefully peel up the UPC code strip on back of player. (There is a tiny screw underneath it)
Carefully remove screw. (The snap notches are 'L' shaped inside the edges of the case).
Gently slide/pry open the backside of the case, taking care NOT to break the snap notches.
Open case, REMOVE BATTERY, THEN PUT IT BACK IN.
Close case, restart/turn on player.
Philips GoGear... | Answered on Nov 10, 2011
The device has a reset hole.
Use a pen tip or other sharp object to insert the RESET hole on the side of the player.
The hole can be found by means of this figure:
If you need a user manual it can be download-able from here.
Thanks.
gylacz
Philips GoGear... | Answered on Sep 20, 2011
Hi nhobbs31...
Try the easy way to delete the files,music,etc.
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
This is a FREE answer, Please take time to rate me
Philips GoGear... | Answered on Sep 19, 2011
Check for Philips Songbird software which is used to transfer data from pc to player
Philips GoGear... | Answered on Aug 04, 2011
Hi peternsue,
The System requirements for this model are:
• Windows XP (SP2 or above)
• Pentium III 800MHz processor or higher
• 256MB RAM
• 200MB hard disk space
• Internet connection (preferable)
• Microsoft Internet Explorer 6.0 or later
• CD-ROM drive
• USB port
You might have more success downloading Software & Drivers directly from the Support Site:
http://ow.ly/5S9au
Hope this helps! If so, let me know by rating this solution.
Philips GoGear... | Answered on Aug 01, 2011
Quick start guide:
http://download.p4c.philips.com/files/p/ppx1430_eu/ppx1430_eu_qsg_eng.pdf
User manual:
http://download.p4c.philips.com/files/p/ppx1430_eu/ppx1430_eu_dfu_eng.pdf
Philips GoGear... | Answered on Jul 16, 2011
Hey the manual is on the UK site: http://bit.ly/qqIuid hope this helps :)
Philips GoGear... | Answered on Jul 15, 2011
There are several different submodels of the SA2RGA. You'll find the manuals for them at the following sites:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04R/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04S/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA08K/37
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2RGA04KS/37
Philips GoGear... | Answered on Jul 13, 2011
Good Day Pledieux!
Better check the data cable that you use to connect your device to your car and PC.
You can try wiggling the plug connector on your mp3 and also the other end connector of the cable that connects with your car and PC. Once it works for a few seconds by wiggling it, then it means you have an open wire on data cable. You will need to replace it.
Philips GoGear... | Answered on Jun 29, 2011
Hi
the Philips Songbird software should be installed on your PC.
it can be downloaded from the URL below..After you install it ;
  • Launch Songbird and then connect your player to your computer.
  • Select "Repair my Philips Go_Gear" under the "Tools" menu.
  • Follow the instructions given by the pop-up windows to perform the process
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=FLASH_AUDIO_PLAYERS_SU&cat=MP3_MEDIA_PLAYERS_CA&grp=SOUND_AND_VISION_GR&session=20110331034822_93.189.114.198&ctn=SA2RGA04R/37&mid=Link_Software&hlt=Link_Software
  • Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Philips GoGear... | Answered on Jun 24, 2011
I'm glad to provide the instructions to copy music files to the player. You can use the supplied SongBird Software or Windows Explorer to transfer music files from Computer to the Player.
When using Windows Explorer, the player will display as an extra drive under My Computer. You can open the drive which represents the player and copy the required audio files to the music folder in the player.
Thanks for understanding. Please let me know if you require further assistance/clarifications.
Philips GoGear... | Answered on Jun 17, 2011
on the bottom of this device. located center bottom is a tiny hole to reset it. Use a pin needle to reset it. Just press it in there till it stops then pull out and see if it powers up.
Philips GoGear... | Answered on May 17, 2011
Philips GoGear SA2RGA MP3 Player Logo
57 questions posted
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
GOGEAR Philips
  • GOGEAR Philips
Most Popular Question
unfreeze mp3 player
  • Audio Players & Recorders
