20 Most Recent Russell Hobbs RHCK1 Electric Kettle Questions & Answers
Russell hobbs wisper quiet kettle
If it leaks now, it will in 2 weeks.....take it back.
7/25/2007 3:49:32 PM • Russell Hobbs... • Answered on Jul 25, 2007
Russell Hobbs fridge freezer. E5 error on it?
This link might work better for you. This is not a North American brand where we are. https://www.google.com/search?q=Russell+Hobbs+fridge+freezer.+E5+error ..
11/16/2022 5:43:58 AM • Russell Hobbs... • Answered on Nov 16, 2022
2answers
Russell hobbs kettle
You will need to first shock that kettle first bold hot water then remove it and replace with very cold or ice water. The smell like plastic is brought by the Plastic which over heats and somehow weakens to a point of melting thus releasing a smell into your water, Shocking the kettle would help if not then you will need to buy another kettle as that one might not be original or just wasn't tested for regularities and standards.
10/13/2022 4:10:28 PM • Russell Hobbs... • Answered on Oct 13, 2022
Where can I find the serial number for the Russell Hobbs RHPAC4002 portable air conditioner and dehumidifyer?
It may not have one if they only made one batch of them. If it does have one it will be on that sticker. Is it near the mains lead? The other possibility is that there is another sticker inside with serial number and inspector stamp.
8/30/2022 5:07:33 PM • Russell Hobbs... • Answered on Aug 30, 2022
I'd like to know the exact location of the thermal fuse in the Russell Hobbs hot water kettle. The model number is KE5030SPD
img_20220724_093806-blt5ih5nld1hpwo4ithpxfl2-d-0.jpgneed to replace this fuse if any one could advise of an alternate fuse
7/24/2022 11:20:05 AM • Russell Hobbs... • Answered on Jul 24, 2022
Russell Hobbs toaster burns toast
It is a 'pop up toaster'. It should turn off the heat rather than 'reducing' it and pop up. The reviews mention the same. Time for a new one. https://www.google.com/search?q=russell+hobbs+RHT302+burn+toast ..
6/4/2022 11:33:46 PM • Russell Hobbs... • Answered on Jun 04, 2022
RUSSELL HOBBS 18941 KETTLE has slow leak from the bottom of kettle.
They are pretty much a disposable item when they fail. You could try repairing with epoxy putty. Some bases can be screwed a bit tighter. https://www.google.com/search?q=KETTLE+MOD+18941 Manual
RUSSELL HOBBS 18941
and regarding kettle leaks https://www.google.com/search?q=KETTLE+MOD+18941+leak+at+base ..
5/6/2022 1:37:34 AM • Russell Hobbs... • Answered on May 06, 2022
Russell Hobbs kettle 20191. How to get to wiring in base unit of it?
Turn it over and look for screws under the feet. In reality, modern kettles are a disposable commodity.
3/17/2022 8:19:26 PM • Russell Hobbs... • Answered on Mar 17, 2022
I have broken my lift up arm on my Russell Hobbs mixer .Is there a way of fixing this.
What’s the model number
9/27/2021 9:29:25 AM • Russell Hobbs... • Answered on Sep 27, 2021
Can you show instructions for Russell Hobbs bread maker model no. 17887
we cant but you might find them on google
5/1/2021 9:47:07 PM • Russell Hobbs... • Answered on May 01, 2021
Can I buy a replacement plastic gear wheel for the citrus juicer part of a Russell Hobbs juicer model 9919? Please
Probably not. These are not made by Russell Hobbs., Just branded that way.
3/2/2021 3:36:16 PM • Russell Hobbs... • Answered on Mar 02, 2021
My Russell Hobbs Hand Blender not working. It smells of burning, I suspect the fuse is burned. How do I removed the cover; there are no screw? Any help will be appreciated
Edited to Add;The OP changed it from Hand Mixer to Hand Blender, so my information below only applies to a MIXER. She needs a new Stick Blender, you can't repair them.No fuse in those, but there maybe a thermal fuse. If you smell burning, it will be the motor windings overheating.Screws are probably hidden beneath the little rubber pads for setting it down when the beaters aren't in it. Having said that. many newer devices just have locking tabs. You need to use a 'spudger' and find the right place to press and twist. Often with Mixers, the carbon brushes to the motor stick, so a sharp tap will often get them running again.
12/27/2020 1:04:25 AM • Russell Hobbs... • Answered on Dec 27, 2020
I have a russell hobbs 4110 kettle l need the part at the end of the cord that goes into the kettle from the base can you help
Careful russell-hobbs.com appears to *not* be connected with the manufacturer Russel Hobbs (which is RussellHobbs.com). Also, the phone number tries to draw you into a scam gift card
12/2/2020 7:31:42 PM • Russell Hobbs... • Answered on Dec 02, 2020
I HAVE A 14356 RUSSELL HOBBS TOASTER LEVER WILL NOT STAY DOWN
https://www.youtube.com/watch?v=PAk_xv--Nog
4/2/2020 1:32:50 PM • Russell Hobbs... • Answered on Apr 02, 2020
Russell Hobbs RHCK1 Electric Kettle Logo
Popular Tags
2 questions posted
Top Russell Hobbs Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Russell Hobbs Kitchen Appliances - Others
Most Popular Question
russell hobbs wisper quiet kettle
  • Kitchen Appliances - Others
