20 Most Recent
Philips 55PFL7505DF7 55 in LCD TV Questions & Answers
Philips 55 inch tv weirdness
If it is turning off by itself then your power supply might be going out. If it does not bother you too much right now I would wait until it gets worst. Depending on how much you use it it may not get worst in months. You can get parts at
www.interliquidparts.com
12/2/2011 4:07:33 AM •
Philips...
Answered
on Dec 02, 2011
How to install a home
Follow these steps:
•Plan out your setup. Before you start unpacking speakers and moving furniture, it's a good idea to have a placement scheme in mind.
•2
Consider the location of the outlets in your home theatre room. If possible, choose a room powered by a single circuit breaker to reduce the risk of damage due to the overload your home theatre system might cause. Supplement the number of outlets with power strips.
•3
Place your TV. The television should be placed where it can be viewed straight on. The center of the screen should be aligned with the eyes of a seated person.
•4
Place your speakers before you start hooking things up. If there are hearing-imparied people in your household, place the speakers so that someone could sit directly next to at least one speaker.
•5
Position your central channel speaker above or below your TV. If you put it on top of your TV, make sure the front edge of the speaker is aligned evenly with the front of your TV screen.
•6
Place your front left and right speakers at equal distances on either side of your TV. The height of your left and right speakers should match the height of your central channel speaker.
•7
Put your surround speakers at equal distances to the left and right of where you would normally sit and view your TV. Do not point your surround speakers directly at your viewing position. Try pointing them toward the back of the room or toward the ceiling.
•8
Place your subwoofer to the side of the room, about halfway between your viewing position and your TV. You can adjust the bass reaction of your subwoofer by moving it closer to a wall to increase the bass, or by moving it away from a wall to decrease it.
•9
Connect your speakers and theater system by running flat speaker cables down the length of your baseboard or lower portion of your wall. Consult your owner's manual for exact instructions.
3/13/2011 9:14:57 AM •
Philips...
Answered
on Mar 13, 2011
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
Philips tv Model - 21PT3525/V7 I want EHT Number ?
The EHT number for a Philips TV model 21PT3525/V7 can vary depending on the specific version of the TV. However, the EHT number for this model is typically BSC25-0235 or BSC25-0217.
It's important to note that replacing the EHT can be a dangerous process, as it involves working with high voltage components. If you're not experienced with electronics repair, it's recommended to seek assistance from a qualified technician who can perform the repair safely and properly.
3/4/2023 1:03:43 AM •
Philips...
Answered
on Mar 04, 2023
