20 Most Recent Acer Aspire 5742 Notebook Questions & Answers
If you hear a quick click of the dvd/cd unit, and the reboot sequence restarts all over again, endlessly. Most likely this solution will work for you.
1 Unplug the power.
2 Flip the laptop over.
3 Slid the "lock" for the battery so you see red (or the battery is in unlock).
4 Push the other slider mechanism to remove the battery, and slip the battery out of its holder.
5 Take a small Phillips head screw driver and remove the screw in the middle of the back of the laptop.
6 Slide the DVD/CD player out from the side of the laptop.
7 Complete the battery reinstall in reverse steps, plug in the A/C adapter.
7 Power up the laptop.
! Viola - No more boot loop issue.
Now you need a new DVD/CD unit (or you can try to put it back in, sometimes they start working due to a poor connection).
Why? The DVD/CD player in this laptop is a convenient place to pick the laptop up. It gets jostled around a lot. There's also a lot of heat generated right near the units. They also have poor hold down and connections as you will witness, once removed. It is a part of the boot process to check its operation, no work, no boot, it doesn't communicate well either. So it just keeps rebooting not telling you why. Since the player doesn't work, you can't use your recovery discs, lol.
Acer Aspire 5742... | Answered on Jun 30, 2020
If original OS try resetting or refreshing and if without original go to the re-seller for troubleshooting.
Acer Aspire 5742... | Answered on Dec 02, 2017
If machine not booting it could be a bad cmos, hard drive, mo bo, peripheral, corrupted OS, bad power supply, bad memory,
Remove the hard drive and see if it posts and then gives you message that there no boot drive If that does not happen then machine is not even posting which means something is wrong with the cmos. - not a good thing.
Acer Aspire 5742... | Answered on Sep 23, 2017
try : should I remouve it
Acer Aspire 5742... | Answered on Apr 12, 2017
removing the hdd and putting it back some times works,make sure you are turnd off before removing the hdd,if this does not work check all your ram one by one and see if that works.try just one ram on its own and see what happens.
Acer Aspire 5742... | Answered on Oct 26, 2016
This is similar and will stay on Drop Box for 24 hours only
service manual Acer Aspire 5720 5720G pdf
Acer Aspire 5742... | Answered on Jan 14, 2016
Too little RAM, HDD full, Over Heating, Swap File too small ...
Acer Aspire 5742... | Answered on Dec 13, 2015
i think if you pres alt+up arrow should get it back.
Acer Aspire 5742... | Answered on Apr 14, 2015
are you on about the mouse you use on the laptop or a mouse you have added?
Acer Aspire 5742... | Answered on Mar 29, 2015
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Acer Aspire 5742... | Answered on Jan 15, 2015
This typically indicates a hard drive that is failing or experiencing problems. You will need to have the drive tested. Online Virus Removal Best virus removal online
Acer Aspire 5742... | Answered on Dec 02, 2014
Thank you for using fixya. My name is Carlo.
There are two ways that you can do to turn off/on the touch pad in your acer aspire.
1. Press FN + F7. It will turn off the touchpad and will turn on once you press the same buttons again.
2. If the buttons do not work. You can do this:
1. Go to control panel>hardware and devices>Devices and Printers>Mouse
2. CLick on the last setting on the right.
3. Click on Disable in the Mouse Properties.
5. Click OK.
Just go to the same area when you want to enable your touchpad again.
I hope this helps.
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Acer Aspire 5742... | Answered on Aug 23, 2014
Could be the cmos battery low voltage, the processor may be too hot, the video firmware may have errors ... could be all manner of things.
Try updating your drivers after checking the cmos battery.
Acer Aspire 5742... | Answered on May 12, 2014
If your computer is asking for a bootable disk drive on startup, it typically indicates drive failure and your harddrive needs replacement. Sorry for the badnews.
Acer Aspire 5742... | Answered on Jan 14, 2014
Could be almost anything but does it charge the battery? If it does in may be a processor issue if not there is a power supply issue on the main board. Without detailed information, it will not be possible for you to pin point a faulty component as the main board uses DC-DC convertors and one may have stopped oscillating..
Acer Aspire 5742... | Answered on Jan 10, 2014
just check it whether keybord working or not if working just check all key stuckking inside something ofter check once all components are supported are not
Acer Aspire 5742... | Answered on Dec 06, 2013
See this video utube
Acer Aspire 5742... | Answered on Nov 08, 2013
Acer Aspire 5742 Notebook Logo
115 questions posted
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer travelmate 5742 in boot loop think
  • Computers & Internet
