20 Most Recent
Dell Inspiron 1545 Black Intel Celeron 900 22GHz 2GB DDR2 RAM 250GB 5400RPM Hard Drive DVDRW Windo (609722305754) PC Notebook Questions & Answers
How do reset my laptop bios to gain more privileges
Try repeatedly pressing f2 when booting up computer. You should be able to access the bios and then you will want to move th CD-ROM drive to the primary boot position. Save and exit. Then stick disk with new operating system in cd drive and install.
Dell 1545 will not boot after ram installation
Before install the new ram, it is recommended that you wipe off the gold contacts of the new ram with some alcohol. You can also use pencil eraser to wipe off the contact. Did the new modules fit and lock down?Link below to Dell - then download Service Manual. There, you'll find the procedure for removing and installing new memory module. http://www.dell.com/support/Manuals/us/en/04/product/inspiron-1545
Static in speakers when unmuted
keikii_the_p,You may want to uninstall and then reinstall the audio drivers back into the system. You can download your computers drivers at the link below. Hopefully, this will resolve the issue. If not please post back.Inspiron 1545 DriversThank You,Dell-Jesse LDell Social Media and Communities
Wont turn on
Just a query, has the laptop been dropped? If so it may have damaged the internal hard disk drive. If it has not been dropped, can you boot in safe mode?
My Laptop won't power up
try plugging it to another same brand laptop. if the result is the same that means ur power adapter is faulty, if it's ok with other laptop then its ur laptop's power connector & motherboard is faulty
I DONT HAVE A WINDOWS DISK
You can restore your Dell back to the factory default by booting up with the Dell Recovery CD and then follow the instructions. If you do not have a Recovery CD then you can get one for your model Dell laptop from the Dell WEB site.
White screen
the beginning of ugly problems you will need a new video driver card and screen within about 3 to 6 months
How do i align my computer screen
Align my computer screen to fit my screen?
I think you are saying that what is displayed on your screen is not aligned and you can't see everything.
Try adjusting your screen resolution. Click Start/Control Panel and
look for Display or Appearance and Personalization to click on. You
might can just Right Click on a blank area on the display screen and
select Properties. Once you get the Display Properties to open select
the Settings or Resolution tab. Adjust the screen Resolution by sliding
the bar over to the right. The higher the resolution, the smaller the
icons, thereby the more will fit on the screen.
Cd tray not ejectig
Take a Paper Clip (Gem Clip) and straighten it out. Look on the side of the CD Drawer and you will see a tiny hole. Insert the Paper Clip into the hole to force the drawer open. That's why the hole is there.
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
