20 Most Recent
kawasaki 1152 System Questions & Answers
Kawasaki 1152 retail price
recently (Dec 2007) purchased one on eBay for $20 plus $25 shipping (all the way across the US - - the shipping price was not out of line considering the size and distance).
No idea about original price.
Remote code
i need the remote codes for a kawasaki 1152 home theater system
No pic
Check the channel & Vido input
Cant See
do you have your tv set to the correct AV channel (for a scart connection) look at the Scart port on the TV (it should be numbered usually AV1..AV2..etc..)
Then you just need to switch to the appropriate AV channel on your TV
hope this helps.....
also check in your TV manual if the av socket you are connected to is an input or an output.
No sound when watching tv.
I think that all depends on how you have it set up, I'm guessing that you have the speakers connected to the DVD player, however I'm not sure if you have any audio cables running from the TV to the DVD (required if you want this for sound from your TV), I'd check your configuration, as it sounds like you have not got this set up right.
How to set alarm Ikea Slabang clock
1. Press and hold the "+" or "-" button to enter the alarm settings.
2. Press the "+" or "-" button to choose the desired hour for the alarm.
3. Press the SET/RESET button to confirm and move to the minutes setting.
4. Press the "+" or "-" button to choose the desired minutes for the alarm.
5. Press the SET/RESET button to confirm and move to the alarm mode setting.
6. Press the "+" or "-" button to choose the desired alarm mode (i.e. one time, daily, or weekdays).
7. Press the SET/RESET button to confirm and activate the alarm. The ALARM indicator light will turn on when the alarm is active.
8. To turn off the alarm, press the SET/RESET button. The ALARM indicator light will turn off when the alarm is deactivated.
