20 Most Recent Samsung R530 22GHz Intel Core Duo Processor T660 NPR530JA02USK PC Notebook Questions & Answers
2answers
Laptop samsung r530
see my solution posted on other question
9/26/2015 3:32:44 PM • Samsung R530... • Answered on Sep 26, 2015
How do i maximise the screen
goto your control panel and click on your dispaly settings and try and reset from there,
4/12/2015 3:06:16 PM • Samsung R530... • Answered on Apr 12, 2015
My computer screen has lines and keeps fading
replace the screen its faulty
2/3/2015 9:31:01 AM • Samsung R530... • Answered on Feb 03, 2015
My sistam is not restore ... WHY???
This error code usually points to an installation of windows that has been corrupted. I'm assuming that you have no USB flash drives plugged into the laptop when booting, if so, remove these and try a reboot.Then try to boot to safe mode (f8)If this fails, boot from the CD drive by setting the DC boot option as 1st boot in the bios, put the windows installtion CD in the drive and go through the install proceedure, selecting the REPAIR option.If this fails, you will need to reinstall windows.To recover any lost files, after reinstalling windows, download a utility such as recover my files and set it to a format recovery to get any lost files back.
6/21/2012 11:18:14 PM • Samsung R530... • Answered on Jun 21, 2012
Samsung r530 laptop goes back to log on screen if left idle for a few minutes
that is most likely the sleep mode on the screen saveropen with start buttoncontrol paneldisplay iconadjust screen save settings for longerand look to see what happens in power save mode for shutdownshould work welllet me know how this goes
5/25/2012 1:28:17 PM • Samsung R530... • Answered on May 25, 2012
My model is the np355v5c-ao6uk, i got it from the auction, its passworded and l cant get into the system
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed http://wiki.ljackson.us/Control_Userpasswords2 if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware http://download.cnet.com/password-cracker/3000-2092_4-10226556.html password cracker free
5/28/2019 2:54:50 AM • Samsung R... • Answered on May 28, 2019
0answers
The backup folder created by Samsung Recovery Solution has changed how to fix ??
try doing a restore to when you last seen it
4/12/2015 3:23:16 PM • Samsung R... • Answered on Apr 12, 2015
How to hard reset?
Dear There is no hardware reset. however you can opt for the default setup at bios setup before booting. (pressing delete key. Thanks.
4/1/2015 11:25:58 AM • Samsung R... • Answered on Apr 01, 2015
2answers
LAPTOP WILL NOT START
check mains lead and fuse pluse battry,try starting up with out the battry just the mains.
3/30/2015 5:20:43 PM • Samsung R... • Answered on Mar 30, 2015
Samsung R519 irregular beeps on startup
check your ram it could be faulty.or over heating,check and make sure your fan is running.if its the fan get a hoover and clean it out.
3/30/2015 3:54:34 PM • Samsung R... • Answered on Mar 30, 2015
Battery cannot hold the charge
you need to change the battery
3/30/2015 3:45:36 PM • Samsung R... • Answered on Mar 30, 2015
My samsung laptop won't turn on at all. nothing
try starting it up with out the battery just the main lead.,or check the mains lead. check fuse in main lead.
3/30/2015 3:15:48 PM • Samsung R... • Answered on Mar 30, 2015
It prints a descriptive page after each document page, why?
Dear You may do un install and reinstall the application software. Thanks.
3/17/2015 5:54:54 PM • Samsung R... • Answered on Mar 17, 2015
How to hard reset a laptop r430
http://support.hp.com/us-en/document/c01684768
3/17/2015 4:50:11 AM • Samsung R... • Answered on Mar 17, 2015
Where can I get a users manual for a Samsung laptop R 730-live cam.
Have you tried downloading from http://www.samsung.com/us/support/owners/product/NP-R730-JB02US ?
3/8/2015 9:28:58 AM • Samsung R... • Answered on Mar 08, 2015
My screen is too bright
on my keyboard I hold down the FN button and either the up or down arrow key depending on whether you want it brighter or lower
10/4/2014 7:46:52 PM • Samsung R... • Answered on Oct 04, 2014
I had my laptop on during a power outage and now it won't turn on. The light is on showing a connection to the battery and t
Can you power it up with out the battery? Just the power cord, no battery? You very well may have fired it sadly. I think Best Buy Geek Squad may check it out for you free of charge, but I can not be certain of that.
7/23/2014 1:16:47 AM • Samsung R... • Answered on Jul 23, 2014
Samsung R530 22GHz Intel Core Duo Processor T660 NPR530JA02USK PC Notebook Logo
Popular Tags
9 questions posted
Popular Products
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
R Samsung
  • R Samsung
Most Popular Question
laptop samsung r530
  • Computers & Internet
