20 Most Recent Nuance Dragon Naturally Speaking 11 Home Questions & Answers
Microphone picks up sound but i have to yell for
Reset Microphone first,and then try.Also check the entry point(the jack) it could be a simple case of 'loose contact". Warm Regards-
1/14/2018 5:32:45 AM • Nuance Dragon... • Answered on Jan 14, 2018
Dragon skips dictation ---Word shuts off for a few secs then continues with gaps
I would reload the software.
8/31/2017 9:19:38 PM • Nuance Dragon... • Answered on Aug 31, 2017
What is a serial number to install dragan 11 to my Labtop
You can buy one on nuance.com website or even on Amazon and ebay.
8/25/2014 7:57:32 PM • Nuance Dragon... • Answered on Aug 25, 2014
Described it twice you should have it by now
You can contact their official support at: http://www.nuance.com/for-individuals/index.htm
6/28/2014 9:56:31 PM • Nuance Dragon... • Answered on Jun 28, 2014
Lookup serial number
The key might be on the manual or the box if its not on the cd. Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it. The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself. Activation is done online and requires a product serial number. The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual. Start Dragon Naturally Speaking. When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically." Enter the serial number in the space provided and click "Generate Activation Key." Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking. How to activate Dragon NaturallySpeaking without an Internet connection http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
4/27/2013 6:54:54 AM • Nuance Dragon... • Answered on Apr 27, 2013
0answers
How do I stars up dragon?
If you put the CD into the CD drive it should start automatically, if not, go to Start -> My Computer and open it from there. This is assuming your computer meets the requirements of Dragon and that your copy is legiti.
7/18/2011 12:50:44 AM • Nuance Dragon... • Answered on Jul 18, 2011
I installed dragon, I think but I can't find it.
Under the Start menu. Or in Program Files on the C:\ drive, you can find the .exe to launch the program. Or do a search for the program.
3/12/2011 4:29:46 PM • Nuance Dragon... • Answered on Mar 12, 2011
First let me say I
Hi Lynn. I'm sorry to hear about your PC problems.
Reinstalling the program may fix things, but it's hard to nail a precise answer as we don't know what causes the program to fail. Usually programs that require some profile to work, will offer you an option to save the profile for future use. It it's difficult to create a profile from scratch, then go ahead and have the old profile saved, so you don't have to re-create it next time you install DNS. However, from a tech-support perspective, if the program is making an unknown error and fails to start, it may be best to do a fresh install and recreate the profile.
I have a friend that's doing his PhD in theology, and is 80% blind, so he also uses a typing service similar to DNS. The one he uses is free, or maybe it even was a part of the Microsoft Office pack, which comes with typing assistant. All that to say I understand the problems that these typing assistants can cause, and I'll try to help as much as possible so that you can fix the problem and have DNS working.
You may try to reinstall the program, and also run Windows Update (usually at the top of the Start menu) to make sure your system is up to date. Once your system downloads and installs all the addons, restart the PC and go through the DNS install again. Hopefully this would do the job. If it doesn't, let me know and we'll take it from there.
As for the typing service, it's hard to say because it mostly depends on how fast the typist is, and the handwriting of your husband. Naturally, if the handwriting is not easy to read, work will be slower and the cost per page will be higher. So, it may be best to try and find some young adults that don't have a job and that are willing to do the work. The best place to go is to talk to a youth pastor from churches near by, because you'll want someone that you can talk to, someone that will be able to see the text before they make a commitment, and of course you'll want someone that you can trust relatively safely.
Another option is to go to www.freelancer.com and create a job for data entry/typing. I just checked it, there are posts of typing projects but of course, the price varies from project to project and of course you'll have to set your budget before you make the post.
Hope this was helpful. If it was, please vote with a Thumb Up (top right corner of this post). Thank you.
1/20/2011 4:42:16 PM • Nuance Dragon... • Answered on Jan 20, 2011
How to install Nuance dragon naturally speaking Customer Service?
Solution:
  1. Open Dragon NaturallySpeaking.
  2. Go to "NaturallySpeaking > Advanced > Manage Users."
  3. Click on "New".
  4. Enter a name for the user (e.g., John USB).
  5. From the Dictation Source drop-down menu, select "USB Microphone".
  6. Click on "Next".
  7. Follow the instructions in the Audio Setup Wizard to train the user profile.
http://nuance.custhelp.com/app/answers/detail/a_id/2389/~/how-do-i-setup-a-usb-headset-microphone-with-dragon-naturallyspeaking%3F
4/17/2020 9:00:26 AM • Nuance Computers... • Answered on Apr 17, 2020
How to Install Nuance Dragon software your PC ?
To install Dragon NaturallySpeaking:
  1. Insert the first Dragon NaturallySpeaking CD into a CD-ROM drive. ...
  2. Provide the customer information, including the serial number supplied with the Dragon NaturallySpeaking installation.
  3. Choose the installation directory. ...
  4. Install Type Description: ...
  5. The Dragon NaturallySpeaking QuickStart option can be enabled.
http://nuance.custhelp.com/app/answers/list/kw/How%20to%20Install%20Nuance%20Dragon%20software%20your%20PC%20%3F/sno/0/session/L2F2LzEvdGltZS8xNTg2OTM4NDkyL3NpZC9mVTVqJTdFSXZqSjVEUFRyS1pxTTc2WTRJUHJCUTVWR3dsX09pRktSZ2JYak1TSFZFQ19JQVFRQlNOcWtSdkxFZWpCekhIOWlianVoU1hJdEVTeTBtZnBuRG1mZ2JIMUEweHEyOVBwTXgwcEtUbE1kSGhTT3kzTUQ2USUyMSUyMQ%3D%3D/search/1
4/15/2020 8:16:00 AM • Nuance Computers... • Answered on Apr 15, 2020
Disabling campatibite mode
uninstall and install again
1/23/2014 4:22:12 PM • Nuance Computers... • Answered on Jan 23, 2014
4answers
Yoville supp team ymail com
i have been scammed and i need moneycoins-100000000cash-120000000
12/7/2021 1:55:32 AM • Computers &... • Answered 11 hours ago
My Seiki SE50FYT TV shuts off after 40 seconds.
Seems to be a power issue. -Overheating -Short some where in the circuit -Outlet Issue Would advice the get a Tech so check/follow the power & check outlets. AK
12/6/2021 9:33:53 PM • Computers &... • Answered 15 hours ago
6answers
How do i reconnect Outlook 2010 to Exchange?
Make use of this excellent Edb to Pst converter software to recover Exchange server and extract mailbox from EDB file to PST file with all attachments. It retrieve mailbox from EDB file of all Exchange versions and efficiently restore Exchange EDB to PST file without making changes in formatting of Exchange database. Download the Tool from :- Kernel EDB to PST Converter
12/6/2021 6:35:19 PM • Computers &... • Answered 18 hours ago
10answers
How to create a website
To create a website you have to get the domain name first then you have to host that site , to get the good website creation for your company , just visit this site www.tucktail.com/build-own-website , It has the best designing process and dream website gallery for your website
You can use the pre-built designs and contents available here wherein you can just pick a design,make it yours and publish
it..
12/6/2021 6:35:10 PM • Computers &... • Answered 18 hours ago
4answers
I want delete my account of instagram
Hey there, you need to go to settings, there you can close your account...
12/6/2021 6:34:38 PM • Computers &... • Answered 18 hours ago
Nuance Dragon Naturally Speaking 11 Home Logo
22 questions posted
Top Nuance Computers & Internet Experts
 Grubhead
Grubhead
Les Morrison
Les Morrison
ray gallant
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Nuance Computers & Internet
Most Popular Question
first let me say
  • Computers & Internet
