20 Most Recent Curtis CM32020S 32" TV Questions & Answers
Is this tv digital
I have a digital tv by JVC. It says digital box is low I went online and I see this happens to others. One suggestion was unplug the receiver for five minutes. Do you have any other suggestions. I have Dish TV.
5/1/2014 5:18:18 AM • Curtis CM32020S... • Answered on May 01, 2014
No sound on TV,but have picture
Check its speakers. If they are found OK, check the audio output section circuit for faulty component/s.
8/4/2012 4:07:34 PM • Curtis CM32020S... • Answered on Aug 04, 2012
Need owners manual for curtis mathes tv model #cm32020s
Click here to downlaod the user manual to your tV.
4/29/2012 1:46:45 PM • Curtis CM32020S... • Answered on Apr 29, 2012
My direct tv is frozen
That could be a signal or uProcessor problem. I would unplug the mains for a few moments. That will allow the uProcessor to reset. Power it back up and if it is the same, check it with a DVD or Vidoe.
Hope that helps.
3/10/2011 11:01:13 AM • Curtis CM32020S... • Answered on Mar 10, 2011
I have a curtis TVD2002-B 20'' CTRTV/DVD COMBO
check the code for remote,,,or ur universal annt...broke...
8/27/2010 9:28:58 PM • Curtis CM32020S... • Answered on Aug 27, 2010
Channek Picker
Channel picker? I assume that is a channel changer right? Heh. Well, there are many, many, universal remotes. If you go to your local electronic store you can find some to suite your needs. Programming it is another story, but they call come with instructions.
7/12/2010 2:59:36 AM • Curtis CM32020S... • Answered on Jul 12, 2010
I accidentally unprogrammed my remote, it came with
Sound like u have a universal tv remote,could be any brand name models of the univeral remotes.Have to know who made this Universal remote first even have an idea to find the correct codes for it.Try website like Remotes.com spend some money buy the tv original
remote,never will worry about enter codes again,because it the original remote to the tv.
6/2/2010 2:01:11 PM • Curtis CM32020S... • Answered on Jun 02, 2010
No picture appear in the screen of my tv...philips color tv...
sounds like you may need a new tube
4/14/2009 1:26:08 PM • Curtis CM32020S... • Answered on Apr 14, 2009
Picture wnt out suddenly without any symptoms
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!!
4/13/2009 12:58:50 AM • Curtis CM32020S... • Answered on Apr 13, 2009
No picture and clicking sound only
This may be a power supply problem or a shorted horizontal output transistor shorted. The clicking sound is the power supply trying to start but can't because of the overload. Stargazer
2/16/2009 2:13:45 AM • Curtis CM32020S... • Answered on Feb 16, 2009
32" TV MENU IS IN
Try typing the words you see in the meny into a spanish translator to find the correct menu to switch.
I think you should be able to see the word language when in spanish mode.
1/14/2009 4:30:00 AM • Curtis CM32020S... • Answered on Jan 14, 2009
On/off sound
hi
What sounds like? Like a frying pan? a high voltage sparking? or what?
Thanks!
12/27/2008 1:12:13 AM • Curtis CM32020S... • Answered on Dec 27, 2008
2answers
Curtis TV, Mod#LCD2443A: Picture died, Sound is OK. Which part needs replacement - Mother-board or sub-components? Is it a big job, or simple plug-in swap? Any cautionary info? Thanks. Dave
What way you think, working with an LCD TV is skilled work indeed. Here, as sound is OK, there should be something wrong with its picture circuit of the main board. You should have skill in working with main board of an LCD TV. If you haven't it will be best to contact any service technician. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent. {Always respect voltages. While some may not be dangerous in themselves, they can cause unexpected reactions that are best avoided. Before reaching into a powered TV set, it is best to test the high voltage insulation. It is easy to do, and is a good service precaution.}
9/18/2021 11:36:23 PM • Curtis Televison... • Answered on Sep 18, 2021
Curtis mathes tv model# v37ncgi blinking red light do to have a diaogram of where capulators are located?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right column. View it on a desktop or in web View. Mobile view has no search box...
6/6/2021 8:38:50 AM • Curtis Televison... • Answered on Jun 06, 2021
Does Curtis LCD3227A TV work with a Firestick?
Yes, plug it into the HDMI port and enjoy!
2/9/2021 8:27:18 PM • Curtis Televison... • Answered on Feb 09, 2021
My Curtis tv won't turn on for some reason can you help me please
https://www.youtube.com/watch?v=-2P-G9g0mNU https://www.youtube.com/watch?v=9l9mG__rvr8
5/2/2020 5:37:08 PM • Curtis Televison... • Answered on May 02, 2020
Curtis CM32020S 32" TV Logo
Popular Tags
24 questions posted
Top Curtis Televison & Video Experts
 Francisco Mauricio...
Abhinandan  Patil
Abhinandan Patil
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Curtis Televison & Video
Most Popular Question
no sound tv but picture
  • Televison & Video
