20 Most Recent Curtis CM13102 13" TV Questions & Answers
How to reset tcl led b2500
To do a factory reset, you have to enter its 'service mode' option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
7/6/2014 3:41:30 AM • Curtis CM13102... • Answered on Jul 06, 2014
manual
I bought a Curtis 13"
I'm
Having the same problem
With the one I just bought
9/14/2012 8:27:33 PM • Curtis CM13102... • Answered on Sep 14, 2012
The codes of my tve is lost
These are setup codes for Curtis TV;0031 0105 0130 0004 0009 0000 0049 0109 0358 0001 0015
7/8/2012 6:05:33 AM • Curtis CM13102... • Answered on Jul 08, 2012
My universal remote is not
Change battery s in it.
12/25/2010 1:54:04 AM • Curtis CM13102... • Answered on Dec 25, 2010
Hi. Can you please tell
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
12/23/2010 2:42:34 AM • Curtis CM13102... • Answered on Dec 23, 2010
2answers
Old Curtis CMC13003 will not display DVD picture
Radio Shack has a Y adapter to hook up the 2 audio wires together RED/WHITE are audio. 2 females to 1 male Y adapter
5/19/2009 11:07:15 AM • Curtis CM13102... • Answered on May 19, 2009
2answers
Remove Parental Control Password
I have forgotten the password for my parental control/content adviser window. Can you help me either remove it or change it without knowing the existing password. Thank you!!
4/11/2009 11:10:37 PM • Curtis CM13102... • Answered on Apr 11, 2009
Curtis mathis universal control code for 13 in tv cm13102
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
2/6/2009 3:37:24 AM • Curtis CM13102... • Answered on Feb 06, 2009
Sony Trinitron 13 inch older model tv pops & smells at plug
If everything still works OK, then chances are the problem is even before the internal power supply. This could be a component that simply is nearing its lifeend such as a capacitor to ground, a VDR (voltage dependent resistor), a line filter (technically just a coil of wire), or limiting resistor in line with the degaussing coil. This should be a relatively easy/low cost fix and any qualified TV repair professional should be able to do the job pretty quick.
In some instances, there could be nothing wrong with the TV. It is also possible that the smell and pop is an HV (high voltage) discharge due to accumulated dirt, dust and grime anywhere near the anode cap (end od red wire to picture tube) or the FBT (flyback transformer).
Of course, the best would be to seek the services of a qualified TV repair professional since an onsite diagnosis would best serve your purpose.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
5/2/2008 9:08:30 AM • Curtis CM13102... • Answered on May 02, 2008
2answers
Curtis TV, Mod#LCD2443A: Picture died, Sound is OK. Which part needs replacement - Mother-board or sub-components? Is it a big job, or simple plug-in swap? Any cautionary info? Thanks. Dave
What way you think, working with an LCD TV is skilled work indeed. Here, as sound is OK, there should be something wrong with its picture circuit of the main board. You should have skill in working with main board of an LCD TV. If you haven't it will be best to contact any service technician. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent. {Always respect voltages. While some may not be dangerous in themselves, they can cause unexpected reactions that are best avoided. Before reaching into a powered TV set, it is best to test the high voltage insulation. It is easy to do, and is a good service precaution.}
9/18/2021 11:36:23 PM • Curtis Televison... • Answered on Sep 18, 2021
Curtis mathes tv model# v37ncgi blinking red light do to have a diaogram of where capulators are located?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name to your set, in its search box on the right column. View it on a desktop or in web View. Mobile view has no search box...
6/6/2021 8:38:50 AM • Curtis Televison... • Answered on Jun 06, 2021
Does Curtis LCD3227A TV work with a Firestick?
Yes, plug it into the HDMI port and enjoy!
2/9/2021 8:27:18 PM • Curtis Televison... • Answered on Feb 09, 2021
My Curtis tv won't turn on for some reason can you help me please
https://www.youtube.com/watch?v=-2P-G9g0mNU https://www.youtube.com/watch?v=9l9mG__rvr8
5/2/2020 5:37:08 PM • Curtis Televison... • Answered on May 02, 2020
3answers
No sound on my 32" Curtis LCD3227A. I don't have remote and volume button on side of the TV isn't working as well. How do I get sound?
You have two choices to make. One is to get the TV repaired. The second would be to get and outboard tuner box, and feed the picture to the TV, and the audio to a stereo, or other audio amplifier. Those tuner boxes are very cheap compared to getting a repair person to fix the audio problem.
11/2/2019 7:12:59 PM • Curtis Televison... • Answered on Nov 02, 2019
Curtis CM13102 13" TV Logo
12 questions posted
Top Curtis Televison & Video Experts
 Francisco Mauricio...
Abhinandan  Patil
Abhinandan Patil
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Curtis Televison & Video
Most Popular Question
remove parental control password
  • Televison & Video
