20 Most Recent
Packard Bell W3301 Notebook Questions & Answers
I want to reformat PB
Packard Bell is a computer manufacturer, now owned by Acer. Restoring your computer will erase the hard drive and install a fresh copy of Microsoft Windows. This is beneficial if the Packard Bell is showing its age and running extremely slow or has been hit with an incurable virus infection. Before attempting to restore the system, be sure to back up any data you wish to save.
1.Insert the Windows Setup CD/DVD into the computer's optical drive. The disc will have been included with the Packard Bell computer.
2.Restart the computer with the disc inserted. A black screen will appear when the disc is detected, displaying "Press any key to boot from CD or DVD..." Press any key on the keyboard to launch the Windows installer. The "Install Windows" screen will appear.
3.Click "Next."
4.Select "I accept the license terms" and click "Next."
5.Click "Custom" when asked what type of installation you'd like. The other option is "Upgrade," but in order to restore your Packard Bell system to its factory settings, you must reformat the hard drive.
6.Click "Drive Options" when asked where to install Windows. Select the C: drive and click "Erase." Select the unallocated space after it has been erased, and click "Format." Format the space using the "NTFS" file system.
7.Click "Next" and Windows will begin reinstalling on the Packard Bell's hard drive. The system will reboot when finished and launch into your newly restored Packard Bell.
Hi there , i have got a en easynote packard bell
In Device manager, check there are no yellow exclamation marks next to the networking devices, this would show that the computer has a problem with the card
Remove the inspection hatch at the bottom of the laptop, check if the Black (main) and white (aux) leads are snapped onto the brass posts of the card..firmly.
Repost if no luck, It does sound like a failing card to me
Packard Bell iMedia S3720 startup problem
The battery charges the BIOS and is not utilized directly. Sometimes it takes a few days for it to take effect. Placing the battery may have stressed the Setup so my advise is to reset the BIOS. There may be a jumper over two out of three pins and reset takes as much as placing it over the other two for a couple of seconds. When this does not work then remove the battery and replace it after waiting but are you sure the battery is placed right, deep enough and not upside down? Some computers have two contacts that should be shorted out for a moment.
I am not sure what you mean by removed harddisk. It may not function without a suitable harddisk and one fit for the limitations of the BIOS version. When it is on PATA cables, then make sure the Master/Slave jumper is set and the cable its longer end is on the motherboard controller.
Beeps usually give an error code, where a long beep may indicate that a harddisk wasn't found. The very short and almost silent beep means the memory can be tested prior to boot. Perhaps the memory is unfit or displaced.
When any of this does not help you may need some-one on site to take a look at it. PSU's can be diagnosed with a tester plug and those don't have to cost much.
What might be the problem if my laptop doesn't get to password stage? It stuck on the Packard bell logo
What might be the problem if my laptop doesn't get to password stage? It stuck on the Packard bell logo?
well the PC is not 100% dead, and the screen works
no model PB told at all or sold in what country?> where?
this can be simple to worse. (20 things can fail here)
1:: do the 10second long power button reset.? cures stuck sleep
fails.
2: remove the huge battery and RUN on AC power pack only?
batteries are A#1 case of failures and this test is fast and proof.
fails
3: the coin cell battery is dead. replace it. (and reset bios)
fails.
4: the HDD is dead. 5 years old?
no PC told at all and no way for me to judge age, I do tests based on AGE> of PC> to save time , labor and cost of buying useless parts.
5: take unstated PC to a shop, in your unstated town and bingo.
it was not sold in USA./ for decade
and is owned and made by acer.com now.
see the flags here, see yours, , not told you
https://www.packardbell.com/index.html
notebooks
netbook?
tablet
or chromebook???????????????????
