20 Most Recent
Samsung S7070 Diva Cell Phone Questions & Answers
Factory reset
Couple questions:Can you access the O/S of the phone so you could do the reset from there or do you need to do it w/ phone off?What software is the phone running?Rooted/Non-rooted?Thanks,Nick
SAMSUNG GTS7070 WONT TURN ON
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
Forgot my phone lock code
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Free unlocking code for samsung diva
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Samsung diva default pin reset
to hard reset which will completely reset your phone and you will lose all data. back up your phone on a pc. and remove sim. the reset code is *2767*3855# reset at your own risk. thanks
My samsung diva is saying retrieving failed
You have to at least have the pay per use data feature on your line to
be able to get and send mms to and from your wireless phone, just make
sure not to connect to the internet for any other purposes and you wont
have extra charges.
Phone freeze sim unavilable
You need to Unfreeze the Phone,To Unfreeze Your Samsung Diva 7070 Phone use the Unfreeze code,You can get the Unfreeze Code from here
Unlocking4u and Unfreeze it...
