20 Most Recent
PANDIGITAL PANSCN05 Film Scanner (35 mm) Questions & Answers
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scanOnce
you press the SCAN button and the Green LED stays lit its time to roll
the scanner down your document to be scanned. When finished press the
Scan button again to STOP the scan. If successful your Document count
in the display will move from 000 to 001. That is the only indication
that you now have a successful scan.Next Press and hold the SCAN button until the display goes blank.Now
you can remove the memory card (by pushing in and it will release).
Place this memory card into a memory card reader on your computer to
transfer and view your scanned documents. Rinse and repeat.BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:http://www.qvc.com/footers/E167092_quick-start-guide.pdf Good Luck!
