20 Most Recent Cyberhome CH-DVD 402 DVD Player Questions & Answers
Found out on another site that Cyberhome DVD player will only accept certain makes of disc and always struggles with DVD+R. Their was a Firmware update which supposedly solved this problem but this is no longer available, It's old anyway and was very cheap - will buy a new player!!
Cyberhome CH-DVD... • Answered on Mar 17, 2020
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked. There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture. A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV. If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Cyberhome CH-DVD... • Answered on Apr 30, 2017
it could be that the laser head need to be clean
try with the disc cleaner
hope it will help
Cyberhome CH-DVD... • Answered on Nov 30, 2010
clean the lens with a dvd/cd lens cleaner (walmart, radio shack, etc.). or if you're feeling adventurous, remove the top, remove the dvd shuttle cover, and clean the lens with a q-tip dipped in rubbing alcohol. wip it off gently ad blow it dry with your mouth (as opposed to a hair dryer). the alcohol will evaporate. put it together and try it out. if it still doesn't read, you may need to replace the optical pickup (lens and motor).
Cyberhome CH-DVD... • Answered on Jan 06, 2010
Romy... there are "membrane switches" located behind the front panel. Sometimes they go bad or get dirty and won't work. tactmembrane-switch-o5myk4hhi5b5q5if45zblvzs-4-0.png MOST times these are a SINGLE panel with many switches. Often they are a pain to GET and install... Only the right one will work! switch-o5myk4hhi5b5q5if45zblvzs-4-2.png Anthony
Cyberhome... • Answered on May 20, 2018
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Cyberhome... • Answered on Jan 01, 2017
Without a remote control, you can't select anything with this set. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Cyberhome... • Answered on Oct 03, 2016
Cyberhome CH-DVD 402 DVD Player Logo
8 questions posted
Top Cyberhome Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Cyberhome Televison & Video
Most Popular Question
doesnt play dvd
  • Televison & Video
