20 Most Recent Daewoo DTS42 42 in. HD-Ready Plasma Television Questions & Answers
How do I hook up my cable to the tv?im completely lost thank you
In the back or on the side i dont know what model is but there's only one place that the cable can be conected look for the spot that reads ANT.Good luck.
5/13/2016 4:08:19 AM • Daewoo DTS42 42... • Answered on May 13, 2016
2answers
Ownersmanuel \
Hello
Send your Email ID through Fixya to me, or get me a mail to my mail ID. I've the manual you need, and I'll send it to you by return mail. It is a large file and I cannot send it to you by this site, as it allows me to upload upto 50KB only, and the manual has a capacity of 4MB approximately. OK.
[email protected]
Mention your need also by mail, as I may forget this.
2/20/2011 2:29:52 PM • Daewoo DTS42 42... • Answered on Feb 20, 2011
Daewoo 42" DTS HD Plasma
Yeah, this TV has problems, look into replacing it's power supply board
http://www.google.com/url?sa=t&source=web&ct=res&cd=4&url=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-67261-24966-0%2F2%3Fmpre%3Dhttp%253A%252F%252Fcgi.ebay.com%252FDAEWOO-DTS-42-Plasma-TV-POWER-SUPPLY-BOARD-1H217W_W0QQitemZ350192148676QQcmdZViewItem%26itemid%3D350192148676&ei=MzPJSrvmApDSsgOu65miBQ&usg=AFQjCNGqyxaJLx8y2wadBxxtd36ld6AFsA&sig2=eG7Zzl2d0jIPoQLcOyFjvQ
10/4/2009 11:44:15 PM • Daewoo DTS42 42... • Answered on Oct 04, 2009
I have a daewoo dts-42, sound and power but screen
Where did you connect the Video too?, are you using RCA, S video?
10/4/2009 11:43:16 PM • Daewoo DTS42 42... • Answered on Oct 04, 2009
2answers
No sound from daewoo 42" plasma
This particular model doesn't have internal speakers. It has two removable external speakers mounted on the left and right side of the tv. If you didn't get the external speakers with the tv, you won't have sound unless you use a surround sound setup.
10/4/2009 11:42:24 PM • Daewoo DTS42 42... • Answered on Oct 04, 2009
LG 22LC2D SHOW BLACK AND WHITE
its the pdp screen is bad
8/16/2009 1:57:28 PM • Daewoo DTS42 42... • Answered on Aug 16, 2009
3answers
Lines on screen
My daewoo has the same problem. I am told an NEC 942-200529 Digital board "should" fix the problem... I have one on the way, I will try to keep posted.
4/20/2009 1:41:46 AM • Daewoo DTS42 42... • Answered on Apr 20, 2009
My son sat on the remote and we 1/4th of the screen is dark.
There should be a button called Aspect or Aspect Ratio on either the TV's remote or the remote for you cable box/satellite receiver.  Try one of these and keep pressing the button as it will cycle whatever options there are.  If you see a Zoom button, ignore this as this will only make matters worse as some of the image will be cropped off.
4/3/2009 1:42:17 AM • Daewoo DTS42 42... • Answered on Apr 03, 2009
2answers
Blue Vertical Line
sounds like a panel defect or a loose ribbon cable, but more than likely it's the panel itself
11/3/2008 5:48:56 AM • Daewoo DTS42 42... • Answered on Nov 03, 2008
Daewoo DTS42 plasma problems, please help!
The PDP (plasma display panel) is defective and needs to be replaced. The big problem is that Daewoo no longer carries replacement panels for this model. I'm in the same boat you're in. I hate to throw away the tv so I'm waiting to see if I can find a replacement panel on ebay.
11/3/2008 5:35:00 AM • Daewoo DTS42 42... • Answered on Nov 03, 2008
Fix it myself what to do
Check the LVDS cable and all the other cables inside to make sure that they are plugged in all the way, otherwise it could be a bad panel
4/16/2007 2:25:54 AM • Daewoo DTS42 42... • Answered on Apr 16, 2007
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard. https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
2/13/2024 9:26:30 PM • Daewoo Televison... • Answered on Feb 13, 2024
Daewoo DLT37C3. My T.V won't turn back on. The led lights are blinking from green to red. Help please.
Your TV might of had died. Or it is due to the power supply not working anymore.It might be the power cord is bad for the TV.
5/4/2023 6:06:48 AM • Daewoo Televison... • Answered on May 04, 2023
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
2/24/2023 7:52:16 PM • Daewoo Televison... • Answered on Feb 24, 2023
Help my daewoo start button doesn't work all the rest do what is wrong please .
It is difficult to determine the exact cause of the problem without first inspecting the vehicle. A few possible causes could be a faulty start button, a faulty dashboard control module, a bad ignition switch, or a problem with the wiring around the start button. An auto mechanic should be consulted to diagnose the exact cause of the problem.
2/24/2023 7:51:24 PM • Daewoo Televison... • Answered on Feb 24, 2023
2answers
Daewoo DVD/VHS DF-4700PN has display stuck on 'HI--' and doesn't respond to any buttons on either recorder itself or remote. Any idea what I'm doing wrong or what's wrong with the recorder?
Hi. go to this link and you might be able to download the manual for free or find out how to fix your problem. https://www.google.com/search?client=avast-a-1&q=Daewoo+DVD%2FVHS+DF-4700PN+has+display+stuck+on+%27HI&oq=Daewoo+DVD%2FVHS+DF-4700PN+has+display+stuck+on+%27HI&aqs=avast..69i57.3860j0j9&ie=UTF-8
9/13/2022 11:28:35 PM • Daewoo Televison... • Answered on Sep 13, 2022
Daewoo DTS42 42 in. HD-Ready Plasma Television Logo
27 questions posted
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Televison & Video
Most Popular Question
no sound from daewoo 42 plasma
  • Televison & Video
