20 Most Recent MFJ 854 RF Current meter, 30mA-3A Questions & Answers
Check on the side of the box it will give the size it requires. It will look like this T50, T40, T25, and so on.
Hand Tools • Answered on Mar 28, 2021
They have an online form... but I have had no luck getting mine replaced. I have broke 2 so far.
Hand Tools • Answered on Apr 09, 2020
Probably torx although we have no idea what your referring to
Hand Tools • Answered on May 09, 2019
Maybe your battery is died, you can replace it on http://www.drillbattery.com.au/buybattery.php/makita_1220_power+tool+battery.html
Hand Tools • Answered on Mar 19, 2019
it is a type of screwdriver bit
Hand Tools • Answered on Jan 03, 2019
they are typically made out of cast iron, often with little bits of concrete infused in them
Hand Tools • Answered on Oct 27, 2018
The pitch of the roof is described as the vertical rise of the roof divided by the horizontal span of the roof. The pitch of the roof is known as slope, and this happens to be a tangent function. When pitches are kept below 3.5, they are considered as low pitch, and when the pitch is kept from 3.5 to 7.5, it is considered as medium pitch anything above than 7.5 is considered to be a steep pitch. Depending on your requirement and style of construction you can decide the pitch of your roof. Click on Gotcha Covered Contracting to know more about roofing.
Hand Tools • Answered on Oct 07, 2018
I have a box of 5000 8mm 960/101 Vanguard Primo Staples - offer me something to cover the postage!
Hand Tools • Answered on Aug 29, 2018
When you are working with brick or concrete, you should check out the Black & Decker DR670 Hammer Drill. It is specifically made to tackle this purpose.
Hand Tools • Answered on Jun 07, 2018
This is just generic instructions just to give you an idea of placement and mounting. I am not sure if your vise turns or not and that would be a big factor also. It depends on where you want it, if anything is close that will interfere with the vise or whatever you have in the vise. Depends how thick the spot is where you want to mount it. If the place is not very thick, use bolt and heavy washer on top of the vise and a heavy washer, a lock washer and nut on bottom. In place of the lock washer and nut, you could use locknut. If the bench where you want to mount is too thick for bolts, use at least 2" lag bolts with heavy washers with the lag bolts as big as the vise holes will accept. You will need the vise as close to the edge without it hanging over the edge of the bench. This is so you will be able to open and close the vise without obstruction. If placement of the vise isn't a big deal, the center edge of the bench would be great although I always mount mine on one end of the bench because of better movement of the part in the vise. Goodluck.
Hand Tools • Answered on Jun 03, 2018
Unfortunately you need an expensive scan tool that can read all the other individual modules of a car. The Mercedes Benz cars have many of these and without information, it is very hard to work on. It sounds like a body module is acting up.
Hand Tools • Answered on Apr 22, 2018
This torque wrench requires 2 LR44 button batteries (1.5V ea). Here's an Amazon page for this type: Strip of 10 Energizer A76 LR44 1 5v Alkaline Batteries Home Depot provides the manual PDF for download on their website: https://www.homedepot.com/catalog/pdfimages/5f/5f26d0d8-9508-4807-80aa-3654f94e6609.pdf
Hand Tools • Answered on Apr 02, 2018
What's your question?
Hand Tools • Answered on Mar 16, 2018
If the battery has been used a lot or has not been kept charged up it likely is shot. A battery that is not used a lot should be kept charged. I keep my battery operated drill on the charger almost all the time. I have two and change them once every two weeks. Several years old and they both work good.
Hand Tools • Answered on Mar 12, 2018
any wire that says batt is always live in the fuse box.
Hand Tools • Answered on Jan 16, 2018
Generally the repair is more costly then just getting a new one, especially black and decker
Hand Tools • Answered on Jan 09, 2018
noty a question for fixya site get the correct manufacturers site up and ask them
Hand Tools • Answered on Dec 20, 2017
may get a break down from the manufacturer on line but from experience junk it and get a new one easier on the nerves and less frustration
Hand Tools • Answered on Nov 15, 2017
MFJ 854 RF Current meter, 30mA-3A Logo
0 questions posted
Top MFJ Hand Tools Experts
efs_perpends
efs_perpends
Pieter Vleeshouwers
Pieter Vleeshouwers
Bill Boyd
Are you a MFJ Hand Tool Expert? Answer questions, earn points and help others
View Most Popular
MFJ Hand Tools
  • MFJ Hand Tools
Most Popular Question
get repair parts gerber 600
  • Hand Tools
