20 Most Recent Sharp AR 201 Copier Questions & Answers
the chip on your toner cart is bad or not the correct one. you need to change your toner cart.
Sharp AR 201... | Answered on Oct 06, 2014
No it's not. Your best bet is to try an HP driver.
If you're ready for a new machine I can give you a quote!
Skelton Business Equipment Houston Copiers
Sharp AR 201... | Answered on Aug 06, 2014
check fusing unit first and then reset error code.
Sharp AR 201... | Answered on Jan 07, 2014
Go to service mode, then in system 1, and in 'Machine" setting option you can the sensors.
Sharp AR 201... | Answered on Feb 15, 2013
On a Sharp AR-201, the developer light comes on when 50,000 pages have been made since the technician (or factory,) last changed the developer substance and reset the counter. A tech should come out with a Preventative Maintenance kit because training is needed to remove the developer substance safely as well as to clean the optics, interior and inspect the fixing unit, drum and cleaning blade and vacuum out the copier. You should call for service and tell them the developer light is on so they know to bring a kit. And yes... I am factory trained on this model. Retired now.
Sharp AR 201... | Answered on Nov 24, 2012
# * C * den start batan the copier will re-start
Sharp AR 201... | Answered on Dec 01, 2011
Have you tried a trouble clear?
Sharp AR 201... | Answered on Jul 12, 2011
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Sharp AR 201... | Answered on Feb 10, 2011
need complete report where jaming and after how many copies
Sharp AR 201... | Answered on Feb 07, 2011
What is wrong with it? It is a workhorse. I would say yes.
Sharp AR 201... | Answered on Dec 14, 2010
the error F5 02 means that the copy lamp lighting is abnormal.
This is what is in the service manual:
F5 02 Content Copy lamp lighting abnormality
Details The copy lamp does not light up.
Cause Copy lamp error
Copy lamp harness abnormality
CCD PWB harness abnormality
Check and remedy
Check the copy lamp (SIM 5-3)
When the lamp lights:
Check the harnesses and connectors
between the CCD unit and the MCU PWB.
When the lamp does not light:
Check the harness and connector
between the copy lamp and the MCU PWB.
Replace the copy lamp unit.
Replace the MCU PWB.
Remarks Copy lamp disconnection
Cable is not attached.
You must call a tech to solv your problem.
Sharp AR 201... | Answered on Dec 01, 2010
its means you need to replace toner just replace a new toner cartridge
Sharp AR 201... | Answered on Nov 25, 2010
press the ff. botton to reset that error press #/p, * , clear, * then enter 16 then press start
Sharp AR 201... | Answered on Nov 22, 2010
Sharp AR 201 Copier Logo
38 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
error code
  • Office Equipment & Supplies
