20 Most Recent
Sharp PROJECTOR LAMP, Projector Lamp FOR XG-E650UB, 250 WTS, 2000 HRS => Model SPPL021 Questions & Answers
My xg-e650ub also shut down while in use, and won't power up.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
I have a Sharp LCD Projector, Model #XG-E650UB
are there any leds lit? if not, it may be the bimetal circuit breaker. if the unit overheats, the breaker trips to cut the heat source, and needs to be reset manually. unfortunately, the top needs to be removed. it's located on top of the lamp housing (red button). if it's not tripped and still no power, you need to replace the power supply.
Sharp XG-E650UB LCD Projector
Absolutely, they are designed to do so. You will need a svideo cable for video if your laptop doesn't have a parallel port for external monitor. Most projectors have svideo and parallel ports to use them as monitors. If using the external monitor option you select the alt/enter buttons to display on projector.
Model XG-E650UB. I have connected it to my laptop
Make sure your input on the projector is set correctly. Those are old projectors which take a max resolution of 800x600 ( I Think it's been about 5 years since i've seen one ) so on your pc, right click on the desktop, goto properties, settings and crank your screen's resolution right down to 800x600 or 640x480 and press the sync? button on the projector and see how you go.
Happy projecting!
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
