20 Most Recent Mercury Mark 75 Outboard Boat Motor (Mercury Marine) Questions & Answers
Looks like this;
Product Line Year H.P. Model Number Model Description MERCURY 1985 7.5 1007205 7.5 /9.8 H.P.
Mercury Mark 75... | Answered on Jun 09, 2019
Good Morning John,
Please replace The fuel Pump Diaphragm.
It Comes In a Kit Should solve Your Problem But needs To Be Replaced If It Hasn't Already Been Done,
It will be a good starting Point to solving Your Problem.
Regards Gordy
Mercury Mark 75... | Answered on Mar 14, 2019
Good Morning,
From What you have Explained This Is Normal The cooling System Is Joined To the exhaust System So Water Will Come Out through the Exhaust And Pass Through the Proppeller.
Hope This Helps You
Gordy
Good Day
The Carburettors Need Servicing And float Levels Adjusted correctly
Mercury Mark 75... | Answered on Nov 02, 2017
Sounds like the impeller in the lower half of the gearcase is dead. Find a qualified technician.
Mercury Mark 75... | Answered on Nov 06, 2014
pending on how old your engine is coz the price of the full system is lots and mite be more than what your engines worth so check on price of engine with it fitted !
Mercury Mark 75... | Answered on May 29, 2014
Take out filler plug and turn upside down
Mercury Mark 75... | Answered on Oct 05, 2013
Most of those early 6cylinder mercks were dual coil fired on a dual points system with one coil firing 3 cylinders and the other firing the remaining 3 cylinders. They later came up with an electronic IR shutter system for running a switch box. Neither system was something for the average back yarder to be fooling with. The belt drive was critical for clearances and settings.
SO- check to see if it has power to the ignition (about the only thing you can fix) and if it does- find some old timer Mercury guy to fix it for you.
Mercury Mark 75... | Answered on Oct 11, 2012
That serial number was produced during the years of 1988 through 1990.
Mercury Boating | Answered on Oct 21, 2019
Take out the spark plug. Hold a drinking straw up to the spray nozzle and shoot the fog into the spark plug hole.
Mercury Boating | Answered on Sep 30, 2019
Depends on the HP of the motor. The long shaft will only ad a few lbs. See this link for motor specs on weights.
https://www.nadaguides.com/Boats/2005/mercury/outboard-motors
Mercury Boating | Answered on Sep 25, 2019
Best not to do it as you will get maybe 2 mph. Also, I believe it is ******* to modify 1996 and later motors.
Mercury Boating | Answered on Sep 09, 2019
Mercury Mark 75 Outboard Boat Motor (Mercury Marine) Logo
20 questions posted
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
View Most Popular
Mercury Boating
  • Mercury Boating
Most Popular Question
drain hydraulic oil from mercury
  • Boating
