1.make sure your battery good condition.
2. make sure installed properly.
3. reset movement there is two whole on circuit board use stapler pin to connect both whole for one second remove pin
your watch display should show up .
They all set pretty much the same. Here is the general walk through from the Cole site:
Press the lower left button on the Kenneth Cole digital watches to cycle through the various modes. Press it three times to get into time mode (the face should be blinking). Press the upper right-hand button to change the seconds. Press the lower right-hand button to select the minutes.
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
Are the hands moving but out of step with the digital display?
If so then try pressing the "mode" button to reach a mode that allows you to set the hands (on my Casio it is "HS"), I would expect something similar on yours.
You can then alter the hands by pressing one of the other buttons. I would expect one button to advance the hands and another to ****** them.
Just enter the number from the back of your watch into the search box, and download the instruction manual. Get manuals for Kenneth Cole, Timberland, Ted ...
Ive heard people say many times to put cell phones in a bowl of dry white rice to remove moisture from them,so Im sure it would work for a watch as well. Just make sure to leave the watch in the rice over night,and make sure to have none of the watch showing in the rice---it will need to pull moisture from within the tiny parts.
