20 Most Recent Bose Companion 2 Computer Speakers Questions & Answers
currently trouble shooting Bose Companion 2 computer speakers, no sound from speaker, would like to know how to open cabinet to see if wires are attached to speaker?
Bose Companion 2... | Answered on Nov 04, 2015
6 retaining plastic clips. Just opened these myself. Use a screwdriver at the retaining clip locations and turn it sideways; pops the front off, then there's just foam and the speaker inside.
Bose Companion 2... | Answered on Aug 22, 2015
The guy before me is just speaking nonsense. Sonically welded? lol I just opened these today. There are 6 retaining clips; 2 on each side, 1 on top, 1 on bottom. Put a screwdriver in the seam, turn it sideways; try to put a cushion between it and the plastic to not damage the plastic. Simple as that.
Hello
You have only two speakers with you to be connected. There is no surround or subwoofer. So connect the output of computers' FRONTL/R to the speaker system. The amp inside the speaker system will do the rest. OK.
Bose Companion 2... | Answered on Jun 12, 2015
The coil inside the speaker is very tiny and if it loosens contact to main line to the jack, it may have open or short wirings inside. Or that one of the lines have shortages. If you can use a voltmeter tester, you can check if it has open or short wirings. If it's just both, then you can change the wire from the speaker to the jack. But if it stills hums, then there must be loose connection inside the speaker, so you need to replace the speaker with the same wattage and diameter available in electronics stores.
Thanks.
Blessings.
try to see if the power plug in and the supply adaptor connected to the wall
Bose Companion 2... | Answered on Apr 19, 2014
Ir you are lucky it will be your power supply that's gone dead. Use a volt meter to see if the power supply is working or try to find a power supply with the same characteristics (voltage, polarity and amperage). If that doesn't work, the amplifier may be busted. If so you'll need new speakers.
Bose Companion 2... | Answered on Apr 18, 2014
Bose Companion 2 Computer Speakers Logo
96 questions posted
Top Bose Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
bose speakers each
  • Audio Players & Recorders
