20 Most Recent
Williams Wall Heaters: 30,000 Btu/hr Direct-Vent Furnace Natural Gas with Wall or Cabinet-Mounted Thermostat 3003622 Questions & Answers
Williams wall heater in California
Yes it sounds like it does. There should be no carbon monoxide in the environment. I am sure you know how dangerous CO is? Can your gas utility company or a registered gas technician to check it. The heat exchanger should be a replaceable part.
Adding a photo to my inquiry?
That probably means too much fuel or not enough air for correct combustion to take place.
I would check its settings.
Gas wall furnace pilot goes out when burner turns off.
When the main burner turns off, does it make a whoosh or pop? If so, this would be the issue causing the pilot to be disturbed. And have you tried to adjust the pilot/thermopile strength, if possible? A stronger pilot may help. Now if the main burner slowly goes out, and the pilot also slowly goes out, and also slow to ignite, and you've replaced about everything else, it may be the gas valve itself that has/is giving up. Gas is impure and causes a sticky residue. And if the main burner is "slow to act", this tells me the piston that's inside the valve is slowly opening or closing, and may be the reason the pilot is acting up. Make sure you check the outlet to your flue pipe also for obstructions. If the unit doesn't vent properly it can have more heat in the flue. That heat can have a downward rush when the burner goes out, kinda like forcing air through a clogged tube. And when you quit forcing the air, some of it comes back at you. Before condemning the valve try to check all else as you have done with the thermopile and such. Please work safe and I hope this helps.
