20 Most Recent Hitachi 160GB Travelstar Z5K320 SATA 3Gbs 25 Internal SATA II Hard Drive Questions & Answers
Won' recognized my external hitachi z5k320
check data cable. change use port and check the driver on any other PC. if problem is same after doing so. check hard drive Cage. change driver Cage
7/21/2014 12:48:15 PM • Hitachi 160GB... • Answered on Jul 21, 2014
2answers
I bought a
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
3/15/2011 11:39:30 PM • Hitachi 160GB... • Answered on Mar 15, 2011
3answers
Transfer data and operating system from one hard drive to another
Use AOMEI Partition Assistant,a free Windows partition software, to clone data or OS from one hard drive to another. http://www.disk-partition.com/copy-disk-partition-wizard.html
8/18/2017 9:10:08 AM • Hitachi... • Answered on Aug 18, 2017
0answers
0answers
0answers
Where can i find drivers for travelsrar 5k500 b-250
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. Hope this helps.
1/11/2013 3:13:41 AM • Hitachi... • Answered on Jan 11, 2013
Hitachi 50hyt62u H can I add a removable drive as I have a slot in Back for one, and if so where do I get one
You should be able to buy an external USB drive (or thumb drive) at any electronics store. You can connect a USB hard disk drive or USB memory stick to your TV by using the USB inputs of the TV. This feature allows you to play files stored in a USB drive. 2.5" and 3.5" inch (hdd with external power supply) external hard disk drives are supported. IMPORTANT! You should back up your files before making any connections to the TV set in order to avoid any possible data loss. Manufacturer will not be responsible for any file damage or data loss. It is possible that certain types of USB devices (e.g. MP3 Players) or USB hard disk drives/memory sticks may not be compatible with this TV. Quickly plugging and unplugging USB devices, is a very hazardous operation. Do not repeatedly quickly plug and unplug the drive. This may cause physical damage to the USB player and USB device itself. Do not pull out USB module while playing a file. Media Browser Menu You can play photo, music, and movie files stored on a USB disk by connecting it to your TV and using the Media Browser screen. To do this, perform the following: Connect a USB disk to one of the USB inputs located on the side of the TV. You can connect two USB devices to your TV. If both USB devices include music, picture or video files, USB selection OSD will be displayed on the screen. The first USB device connected to the TV will be named as USB Drive1. Select a device by using up or down arrows and press OK
11/30/2019 1:10:18 PM • Hitachi... • Answered on Nov 30, 2019
How to connect my Mac book pro to a Hitachi projector
You will have to use the HDMI port on the mac. provided you have a HDMI input in the projector
11/26/2019 12:41:17 AM • Hitachi... • Answered on Nov 26, 2019
HiTaChI pRinTeR inStaLlAtIoN cuStOmEr sErViCe nUmBeR $1.{877}*{76.9}*{09.69}*#$ 24/7
BENJAMIN, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/7/2019 5:39:59 AM • Hitachi... • Answered on Nov 07, 2019
Hitachi 160GB Travelstar Z5K320 SATA 3Gbs 25 Internal SATA II Hard Drive Logo
5 questions posted
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
TravelStar Hitachi
  • TravelStar Hitachi
Most Popular Question
won recognized external hitachi z5k320
  • Computers & Internet
