20 Most Recent Sharp Notevision XG-NV6XU Multimedia Projector Questions & Answers
if the fans continue to run after the lamp shuts off, there may be an overheating issue. blow the dust out it with canned air. the dust keeps in the heat that the projector is trying to expell. also keep things away from the vents. if the fans and the lamp shut off at the same time, you have a power supply issue, usually dried caps due to heat. if it is the power supply, you can send it in for repair or buy the part and do it yourself. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Sharp Notevision... | Answered on Dec 02, 2009
No special tools needed. these units (dlp projectors) are designed so the lamps and color wheels can be changed out by the user. Some can figure out how to do this easily without instructions but to be safe just do a quick search and find step by step instructions. You can also refer to your owner's manual.
Sharp Notevision... | Answered on Sep 09, 2009
bad power board or blown fuse. If you feel comfortable you can take the out case off and follow the power connector to the board. You can then check the fuse. Make sure the unit is unplugged before doing so. If the fuse is fine then you will need to replace the board as it probably has a bad capacitor or resistor. You can find a power board online but to be honest, its probably not worth the money to by a new one. Would probably be cheaper to buy a used one with a bad lamp and cannibalize the power board out of it.
Sharp Notevision... | Answered on Jul 20, 2009
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
The blue device is dying allowing green to shine thru instead of white. Very common problem called color decay. Happens on average about evey3-4000 hours. I suggest next purchase a dlp product, they are immune to this problem. Good luck
The lcd polerizer(not sure this is proper name ) is bad.It has three: red,green,blue and one of them is bad. I also have a similar issue but only on the left side. Took it apart and found the bad one.
Sharp Notevision... | Answered on Apr 05, 2009
This could only be a dirty lens on the unit. try cleaning the unit lens and bulbs using a soft cloth. Sometimes all of this problem came by only dirty bulbs or lens.
Try to check and clean the unit.
Keep me updated & let me know,.
Kindly Accept also my solution..
Regards,
micro
Sharp Notevision... | Answered on Mar 29, 2009
YEP BAD LCD PANEL...
Sharp Notevision... | Answered on Feb 24, 2009
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
[email protected]..
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Sharp Notevision... | Answered on Sep 05, 2008
Your green LCD panel is dead
Sory
Sharp Notevision... | Answered on Jul 17, 2008
reset the lamp hours on your projector
Sharp Notevision... | Answered on Dec 27, 2007
It could be a dirty filter or dust in the intake holes. Vacuum (preferably) or blow out the vent holes. The projector may be overheating because of this.
Sharp Notevision... | Answered on Dec 04, 2007
It sounds like the bulb overheated at some point. Time to replace the bulb.
Sharp Notevision... | Answered on Nov 08, 2007
Perhaps clean the side filter as well as per page E-46 in the manual on following link: http://www.fixya.com/support/t161763-sharp_notevision_6_xg_nv6xu You can find links to email support & FAQ's on this link: http://www.sharpusa.com/products/TypeManuals/0,1083,29,00.html
Sharp Notevision... | Answered on Sep 06, 2007
Sharp Notevision XG-NV6XU Multimedia Projector Logo
21 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
yellow in center picture
  • Office Equipment & Supplies
