20 Most Recent
Coby MP725Digital Media Player Questions & Answers
Headphone jack requires bending the
This problem is common with a lot of MP3 players. It is caused by excessive movement of the headphone jack and causes the headphone jack has worked loose from the circuit board.
To fix this problem the MP3 player needs dismantling and the headphone jack needs resoldering onto the circuit board to get the headphone working properly.
6/30/2011 5:51:19 AM •
Coby...
Answered
on Jun 30, 2011
I want to put videos
From the support internet site of Coby you're able to download Coby Media Manager.
You can use this manager for converting and transferring data.
How to get the manager:
Enter cobyusa.com in the address bar of Internet Explorer.
Next select Support in the page top.
From the support site select Manager fix for the MP822: It is the complete software program.
Follow up the steps to download and install Coby Media Manager, matching your operating system.
After installation, run the Manager.
Select Tools > Device Manager... in the page top of the program.
From Devices List, select MP725.
Add >>
OK , to setup the selected player as your Favorite device.
In Device configuration you can setup the synchronization and see the output file formats for the selected model.
Use the Help [F1] function, for how to work with the Manager.
9/2/2010 7:14:46 AM •
Coby...
Answered
on Sep 02, 2010
How do I erase all
Remove files from MP3 player
http://www.cobyusa.com/?p=faq
Connect the USB cable to your MP3 player, then hook the other end to a free USB port on your computer. Double-click on the MP3 player’s icon to view the music files stored to memory. Scroll through the list of files until you find the ones that you wish to delete. Click on single items you wish to delete. Right-click on the highlighted files to pull down an action list and from there select -Delete. The computer will ask if you really want to throw the file away. Select OK. Exit from the window, then disconnect the USB cable from the MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs.
7/29/2010 2:29:56 PM •
Coby...
Answered
on Jul 29, 2010
How do I get music from itunes to my mp725 8G
iTunes Agent might be of help. Allows you to sync non-Apple devices with iTunes.
http://pcaudiohelp.com/use-itunes-with-your-favorite-mp3-player-or-mobile-phone
4/9/2010 7:35:25 PM •
Coby...
Answered
on Apr 09, 2010
The MP3 isnt read on the computer
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.plug your device on the cable.
12/28/2009 10:21:25 AM •
Coby...
Answered
on Dec 28, 2009
My coby mp725 was working the screen will not turn
The only thing I've found to fix this EXTREMELY annoying problem is to plug it in to your USB on your computer, find it under my computer as a removable device, and format it. It'll wipe everything you've downloaded onto it, and you'll have to start over. The only thing I can think, is that it doesn't like an mp3 that is put on there, or its a piece of ****... one or the other.
12/27/2009 3:49:36 AM •
Coby...
Answered
on Dec 27, 2009
My son had misplaced his coby mp3 player and we
If you can turn the mp3 player ON while being charged on the computer then I am afraid that you may have a now defective internal Rechargeable Lithium Polymer Battery: if this is the case, the cost of getting it replaced may not be justifiable unless you can do it yourself.
ps. if you are handy, since the unit was lost, check for internal corrosion (due to possible moisture contamination) and try gently cleaning it off with rubbing alcohol.
12/22/2009 2:28:21 PM •
Coby...
Answered
on Dec 22, 2009
