20 Most Recent Budda Superdrive 30 Series II Amp Combo Questions & Answers
You best rewire the cabinet to put the two speakers in series. Wire one speaker plus to minus of the other and bring the other lead, one from each speaker to your jack on the cabinet. The amp output impedance is what is set on the switch... for two 8 ohm speakers you would use both jacks to the two speakers BUT ssince you have 4 ohm speakers the ONLY option is for two in series and set the switch to 8 ohms. The amp is ONLY 30 Watts so don't expect too much sound output... You should get a nice CLEAN sound at a reasonable level. If you drive the amp too hard it will clip and you will get garbage.
Budda Superdrive... | Answered on Apr 23, 2011
It is a physical keyboard, but you can download data from the Casio website. The manual is also in the link
https://www.google.com/search?q=download+wk3500
Music | Answered on Feb 26, 2021
https://blog.caristaapp.com/mlb-evo-testers-wanted-q7-q8-a8-827e78827e0f
Music | Answered on Jan 21, 2021
How do I hey the headphones to work ?
Music | Answered on Jan 19, 2021
Video and text based help on the link
https://www.google.com/search?q=Ypg-625+key+is+stuck+upward
Last post will not let me put pictures for some reason so mine says Ibanez 61-12491
Music | Answered on Jan 09, 2021
Just add some adhesive Velcro (hook and loop fastener) The industrial rated for 25 pound should be good for most players, 75 pound rated minimum for Jerry Lee Lewis type players.
Set the stand at the height you want, put the hook tape on the stand leg top and then target the fuzzy strip to the piano. Be aware the pound rating is rated per square inch- so you will want to put a 10 or 12 inch strip of fuzzy on the piano, and 1 or 2 inch strips on the stand leg.
Music | Answered on Dec 20, 2020
This is a common problem with Bugera. And, unfortunately they are made by Behringer who is known to have the worst customer service of all and do not follow through on their warranties.
Music | Answered on Dec 12, 2020
Request the manual from Rogue.
Music | Answered on Dec 07, 2020
It's here $16.15
TOP+ AC Adapter Charger for TC Electronic Vibraclone ...
www.amazon.com > TOP-Adapter-Charger-Electronic-...
Amazon.com: TOP+ AC Adapter Charger for TC Electronic Vibraclone Rotary Effects Pedal Power Supply Cord Mains PSU: Electronics.
Music | Answered on Dec 02, 2020
I suggest checking to make sure those 2 units can actually use the same adapter and also check the polarity on both to see if they are the same. Most stompbox stuff usually has negative on the center of the socket, instead of positive like other devices. If I spend a little time I could find the manuals and find out for myself but, this was my logical "top of my mind" kind of advice. Those values (volts,mA, and polarity) must be known in order to help you further. I believe it will be 9v, a few 100 mA's, and negative in the center on both but, not sure.
Music | Answered on Nov 25, 2020
Contact Clavinova directly to request the manual.
Music | Answered on Nov 11, 2020
Did you get it fixed?
I have exactly the same problem!
Music | Answered on Oct 26, 2020
hi becky
from looking up the model some of the prices were only 30.00 to 40.00 dollars needing repairs other units/ models went higher in price depending on model and if they where in good repair.
so the decision for u would be is this the organ that you want to restore or do you want to look for other units?
Music | Answered on Oct 23, 2020
So I got a used one of these for free because it had the same issue.
I read about battery failure, so I opened up the piano and sure enough the battery had corroded. I also read that the battery is only necessary for the memory feature, which I don’t care too much about. I pulled out the board (super easy to do, no screws or anything, it just pops out) and took it a local electronics/tv repair guy. In about a half hour he took off the battery, fixed a bad trace on the board with a quick solder, and handed it back. $40.
Plugged it back in, bam works like a charm.
As long as there wasn’t too much damage from corrosion, a repair guy should easily be able to do what I described.
I hope this solves your (and anyone else’s) problem!
Music | Answered on Oct 06, 2020
Take it to a music shop. They should be able give you help in finding a good place.
Music | Answered on Aug 01, 2020
https://www.alphapianostudio.com/
"Great teacher (Sandy) with lots of patient. Friendly and nice and also passionate till I have little time to rest my poor little hand. Learned for about a year plus and now can play more fluently and confidently. Price is acceptable and duration is just nice."
Music | Answered on Jun 20, 2020
update it or flash with new latest files
Music | Answered on Jun 12, 2020
Budda Superdrive 30 Series II Amp Combo Logo
1 questions posted
Top Budda Music Experts
Marvin
Marvin
Are you a Budda Music Expert? Answer questions, earn points and help others
View Most Popular
Budda Music
  • Budda Music
Most Popular Question
budda superdrive
  • Music
