20 Most Recent
Entempo Spirit 20 MP3 Player Questions & Answers
My SPI mp3 player does not charge up when plugged
okay i had the same mp3 but the problem was the charger.. not the mp3... so i got a new charger.. and try to even get one for the wall instead the computer.. because they cost about the same and the one for the computer is not all the great in quality.
i hope this helped you at all..
yours, Charisma , age 14
THANKS
Spi video mp3 player
there is a button on the bottom of the player that slides from on to off. When the switch is turned to on press and hold the center button on the face of the device.
That means as the manual says " Boot Failure "...
Now the home website "which isn't working anymore" suggests that you contact support.
They would recommend you a firmware update, me to will do same.
I'll upload a you the user's guide, firmware update, and Quick guide.
http://rapidshare.com/files/33135786/Entempo_Spirit_20_MP3_Player__upped_by_mstr2kx_.zip.html
included readme.txt
read it for extra help
My p47 bluetooth headphone doesn't input any audio from my chromebook
There could be a few reasons why your headphones are not working with your Chromebook. Some possible solutions include:
- Make sure your headphones are fully charged and turned on.
- Check to see if your Chromebook's Bluetooth is turned on and that your headphones are paired with the device.
- Try restarting both your Chromebook and headphones.
- Make sure your Chromebook's operating system and drivers are up to date.
- Check to see if there are any known compatibility issues between your headphones and Chromebook.
- Try resetting your headphones to factory settings
- Try using different headphones with your Chromebook to see if the problem is with the headphones or the Chromebook.
If none of these solutions work, you may need to contact the manufacturer of your headphones for further assistance.
How to set time on acint27wm
I'm sorry, I am not familiar with a device called "acint27wm". Can you please provide more information about the device and what you would like to do specifically with setting the time?
I have a Fisher ca-9335 receiver/amp ..Problem is
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
