20 Most Recent Behringer PMP6000 VP1520 PA Package Questions & Answers
There are NO "yellow" overload LED's period. The clip or overload RED LED's are just above the PFL buttons for selecting a solo channel. There are "yellow" signal received lights (level set) up near the trim controls. In normal operation these will light when signal is received. Here is schematic for the PMP5000 which is really identical for the 6000.
http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html This has part of the DSP and PS and the PA circuits.
Scroll down to "get manual" and click on it to download. Ignore other download links on the page.
Try turning off the Phantom power if it might be on... If that stops the hum, something is the matter with the bypasses feeding Phantom power to those channels... Possible problem might be shorting of one of the coupling caps at the preamp input. The PMH5000 drawings are more accurate at the input circuits. You will note that the level set LED's are the yellows, and the clip/PFL LED's are the red ones. I suspect that RF bypass caps such as C110 or C121 (example typical for channel one) might be shorted. This makes noise on the Phantom power line unbalanced and will get into the channel where one of these caps is shorted. Do a test: Plug a shorting jack that shorts the tip to the sleeve intot he inssert for the channel. With the LOW CUT button up, observe is the level set LED for that channel dims or goes out. If it does, then I supect you have a shorted RF bypass cap at the input..The next test involves driving a KNOWN balanced signal into the XLR jack and using a TRS in tthe inout 1/4 inch, test the levels with an oscilloscope to verify the hot and the return have equal amplitudes. I they don't, congratualtions you have to tear the main board out... lots of knobs and screws to access the inout circuits and verifuy the cause... it could ALSO be a bad transistor in the inout pair, etc...
Behringer... • Answered on Sep 25, 2011
Since all your speakers are passive, indeed there is a problem like what you describe. This is because with the same amount of signal from the board's speakers outputs, the 2520 can't play the same amount of audio with the PASW18. I don't know what other equipment is available (if any) so let me give you some suggestions.
1. Connect in parallel the 2520s at one of the board's output and do the same with the PASW18 at the other channel output. Doing this you will be able to handle one channel (e.g. left) for the main speakers level and the other channel (right) for the sub speakers level. No stereo playback, so set all the inputs to mono.
2. Use another separate amplifier to drive the subs. You have to provide signal to the amp from any LINE LEVEL OUTPUT from the board (using mono is a very good idea since low frequencies have no stereo separation and in this case you could use a single channel amplifier for both subs, parallel connection)
If there is available more equipment post me back in details to give you guide lines.
In case of a problem or clarification or further details needed (connection diagram e.t.c.), don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Behringer... • Answered on Mar 11, 2011
That appears to be Italian in our English speaking website PMP 4000. Start the source a little and then the supply voltage of the amplifiers disappears https://translate.google.ca/?hl=en&tab=TT&sl=auto&tl=en&text=PMP%204000.%20Porneste%20sursa%20putin%20iar%20apoi%20dispare%20tensiunea%20de%20alimentare%20a%20amplificatoarelor&op=translate Only Behringer can fix
Service - Behringer
www.behringer.com > service
SHOULD THE SOFTWARE PROVE DEFECTIVE, YOU ASSUME THE ENTIRE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION. and https://www.behringer.com/product.html?modelCode=P0A8N ..
Behringer Music • Answered on Mar 15, 2021
I am guessing that the parts inside of your mixer are starting to wear out and your mixer is starting to die on you and you should buy a new one and the motor could be going bad too.
Behringer Music • Answered on Feb 23, 2021
There is a problem with the internal circuitry. There may be one of more components that have failed or weakened.
Behringer Music • Answered on Jan 06, 2021
$95 an hour! seriously i don't know why more people haven't tried this, i work two shifts, 2 hours in the day and 2 in the evening...and whats awesome is im working from home so i get more time with my kids. heres where i went Copy Here........EARN75.com
Behringer Music • Answered on Dec 24, 2020
Radio Shack may have the fans or can order it for you take the fan to a local Radio Shack store.
Behringer Music • Answered on Dec 14, 2020
In order to help you we would need the make and model of the mixer.
Behringer Music • Answered on Apr 30, 2020
Behringer recommends using a shielded CAT 5e cable with Ethercon connectors wired to the T568B standard to connect the two. Also you need to make sure that the board is completely powered on before turning on the S32 for proper connection. Make sure you are connecting between the Aes50A ports. When connected you should be able to see a green light next to Aes50A in the main screen. Then you will need to properly route the channels.
Behringer Music • Answered on Nov 13, 2019
See if another audio source connected to the mixer produces the same results. Try with the same cable and then with another cable. The purpose of this procedure is to determine if it is the cable and/or the laptop. (Sound card problem???) or mixer. Is it ALL audio or just specific audio from for instance, a music application? Does it cut out using iTunes? The mixer may have a bad or oxidized input. Try a different input channel? Are you using headphones to listen? It may be the headphone amp? OR, if audio is produced via amped speakers, it may be the mixer output. Does the mixer have metering? Do the meters also cut out? Does the laptop do the same thing if plugging in headphones to the laptop directly (no mixer)?
Behringer Music • Answered on Oct 23, 2019
You have given in detail which is helpful
Behringer Music • Answered on Oct 16, 2019
I looked up what that unit is so I'm not uber familiar and this is before coffee, however, check your effects levels, possibly delays or echos are building up on an individual channel and adding to your total output making it clip. Even if you don't have the effects on output, they can work in the background and clip internally. Is the output sound affected? Magnetic interference is another possibility if you are running it close to pickups, recorders and other high power supplies. Trim levels set too high? I don't know your actual stage setup but these are a couple things I have experienced through the years. Ahh, here's coffee and a drink to you finding your problem.
Behringer Music • Answered on Sep 15, 2019
Hello Geoff, try using an external processor and check that it works well, if so, the problem is that you have the Jack connectors of Effect sending and those of Return of Effects, dirty Apply a couple of drops of oil, type WD40, to a Plug connector and insert and remove them repeatedly in each connector Jack for sending and returning effects I hope you can solve the problem, comment the results Greetings Franco Dosil Hola Geoff, prueba usando un procesador externo y comprueba que funcione bien, si es asi, el problema es que tienes los conectores Jack de envio de Efecto y los de Retorno de Efectos, sucios Aplicale en un conector Plug un par de gotas de aceite, tipo WD40 y entralos y sacalos repetidamente en cada conector Jack de envio y retorno de efectos Espero puedas solucionar el problema, comenta los resultados Saludos Franco Dosil https://media.music-group.com/media/PLM/data/docs/P0A8M/PMP1680S_PMP980S_PMP960M_M_EN.pdf https://c3.zzounds.com/media/PMP1680S_P0A8M_OI_EN_ES_FR-df44b2314272dfc61a7cabe5bb88ecce.pdf
Behringer Music • Answered on May 24, 2019
Behringer PMP6000 VP1520 PA Package Logo
Popular Tags
10 questions posted
Top Behringer Music Experts
midland10
giftof
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
behringer pmp6000 board connected
  • Music
