20 Most Recent Digix BT-100 Portable Bluetooth Wireless Speaker with Microphone BT-100 PURPLE Questions & Answers
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Digix BT-100... | Answered on Mar 20, 2015
There are several issues that may be causing the volume to be very low.
SPEAKER VOLUME:
(1) When you press the Vol+ button on the speaker does it make a beep sound? (It should, even if it can not longer go up or lower).
(2) Be sure to continue pressing the Vol+ Button to ensure that the volume does increase.
(3) While this is rarely an issue, may want to check that the speaker is charged.
DEVICE VOLUME:
*Please note that some devices have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Ensure that Media Volume is on.
(2) Ensure that the volume is turned up on the device by using the devices Vol+ controls
MEDIA VOLUME:
*Please also note that the media being used (Youtube, Hulu, Music Player, etc.) may ALSO have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Check that the volume within the media is turned up as well.
Hope this helps! You can also contact customer service for DIgix at 1-866-770-3688 for further assistance.
Digix BT-100... | Answered on Jul 02, 2014
Digix BT-100... | Answered on Apr 21, 2014
Has the speaker been paired with another device?
Is the device (phone, tablet, etc) paired with another bluetooth device that is within range?
If the answer is YES to either of the above questions this could be what is causing the problem. Please note that most devices (phones, tablets, etc.) can only connect to ONE bluetooth device at a time. Also note that the BT-100 speaker can only connect to ONE device at a time.
Please be sure to double check that the volume for BLUETOOTH on the device (phone, tablet, etc.) is also turned up. Please note that the volume buttons on the speaker may not always control the bluetooth volume via the device.
If the middle button is pressed and HELD for a few seconds, it should end the call. All android phones may not allow this function.
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
This device is Water RESISTANT. IPX-5. It can get wet, be splashed and fall into water. As long as it is quickly removed and too much water does not seep through the top holes the speaker will be fine. It works great in the shower where it will constantly get splashed or pool side.
0000 or 1234
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Digix BT-100... | Answered on Dec 21, 2013
Kathryn,
The speaker can only pair with one device. I had the same issue pairing it with my phone and then to my iPad.
You simply need to unpair it with your daughters iPod by turning off the bluetooth on that iPod, turn off then back ON the speaker and connect again to your own iPod by turning on the Bluetooth, Selecting BT100 from the list and wait for it to say CONNECTED (not paired).
Hope this helps!
Digix BT-100... | Answered on Nov 18, 2013
Back to the shop. Or look in the manual. Next time you better place a problem like this in the category audio, or speakers. It accedentely? is between Digital camera's.
it uses a non replacable built in litium battery charged bt a usb or wall adapto it will last forever
Video Cameras | Answered on Sep 20, 2020
Remove the cassette and reload the tape, or you may try a new tape.
Video Cameras | Answered on Aug 28, 2020
Digix BT-100 Portable Bluetooth Wireless Speaker with Microphone BT-100 PURPLE Logo
Popular Tags
19 questions posted
Top Digix Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Digix Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Digix Video Cameras
  • Digix Video Cameras
Most Popular Question
digix bt 100 portable bluetooth wireless
  • Video Cameras
