20 Most Recent Koss HD 50 Computer Speakers Questions & Answers
Have Koss hd-50 (hand me
i will go through the process of setting up sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check if you need more help with this post a reply hope this helps you
9/21/2011 7:35:19 PM • Koss HD 50... • Answered on Sep 21, 2011
Hello everyone! I have lost my
Three C cell size batteries per speaker is what you use if you are on the go.
http://www.shopping.com/Koss-HD-50/the-paradox-decent-small-computer-speakers/1386310/reviews#tabAnchor
Hmmm.
EACH C cell battery produces 1.5 Volts (DC)
3 times 1.5 Volts (DC) = 4.5 Volts
Total of 9 Volts (DC)
500 MilliAmps?
Your main concern is with the Voltage.
The Amperage can vary. It can be more than needed.
Why?
Because Amperage represents Current.
How much Current is available.
(Water hose example;
Voltage is the speed, or velocity of the water coming out. Amperage is how many gallons per minute that comes out of the hose)
However, you better make sure that EACH speaker receives No more than 4.5 Volts (DC)
Since you do not have the special splitter adapter cord that comes with the power brick, you will have ensure that EACH speaker receives no more than 4.5 volts.
This is if you are trying to use a 9 Volt (DC) power supply. (AC adapter)
Please post additional questions in a Comment.
Regards,
joecoolvette
5/30/2011 8:51:13 PM • Koss HD 50... • Answered on May 30, 2011
3answers
What voltage are the koss
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
3/6/2011 8:20:03 AM • Koss HD 50... • Answered on Mar 06, 2011
My GD-50 KOSS SPEAKERS HAVE
you need an external sound card. plug into your pc or laptop then plug in your speakers , hey presto. prob solved. and cheaply to.
9/11/2010 11:43:17 PM • Koss HD 50... • Answered on Sep 11, 2010
...i lost my installer..
check Koss web site for the driver
2/25/2009 1:19:39 AM • Koss HD 50... • Answered on Feb 25, 2009
Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
10/17/2008 10:33:30 AM • Koss HD 50... • Answered on Oct 17, 2008
Speakers set up properly, but no sound from PC
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer. But there is no sound at all coming out -- just silence.Can You Please Help Me
8/13/2008 12:54:01 AM • Koss HD 50... • Answered on Aug 13, 2008
2answers
Need owner manuel for koss KS5190 digital home
me too help [email protected] Do u need remote to set speakers along with other setting problems including, back speakers not working, tv not on surround sound, can play dvd and tuner still no back speakers, no remote. Do u need remote to set, please help!!!! email [email protected]
12/29/2022 10:23:33 AM • Koss Audio... • Answered on Dec 29, 2022
Does the c-cell batteries have to be installed for sound from my HD-50 Koss speakers
WHY DON'Y YOU PUT THEM IN AND FIND OUT
4/22/2021 3:41:54 PM • Koss Audio... • Answered on Apr 22, 2021
0answers
0answers
Standby light on, but won't power on
.hi guys I have been using the DAV SB300 and all sudden the standby power light flashes any time I try to put it on, any help on how to fix it?
2/10/2018 12:23:52 AM • Koss Audio... • Answered on Feb 10, 2018
0answers
Antenna Loose
Be the first to answer 1/26/2018 12:21:03 AM • Koss Audio... • Posted on Jan 26, 2018Be the first to answer
I just received a KOSS Model #KS5192 and am having a broblem getting nothing out of any speaker, don't have a manual
https://www.manualslib.com/manual/90227/Koss-Ks4192.html
1/6/2018 9:19:25 PM • Koss Audio... • Answered on Jan 06, 2018
I have the HG1505 Koss
The player is no longer any good. Sorry.
9/8/2017 3:10:08 AM • Koss Audio... • Answered on Sep 08, 2017
Koss HD 50 Computer Speakers Logo
11 questions posted
Popular Products
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Marvin
Marvin
 Grubhead
Grubhead
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Koss Audio Players & Recorders
Most Popular Question
everyone lost
  • Audio Players & Recorders
