20 Most Recent
Hitachi 35IN LIFESTUDIO DESKTOP 1TB EXTERNAL 0S02662 USB 20 Hard Drive Questions & Answers
Clicking noise
Backup it immediately if you want your files. The next step is a total faillure of HD
Lifestudio isn't installed on my pc anymore
1. From what I read it may be the port drivers that are not installing for the USB port you have connected you hard drive to.2. Check the manufacturers site for driver updates and hard drive requirements 3. It may be that the driver are not for the OS that you have or you may have to download them.4. Try another cable ( USB)5. Last it may be the internal electronics of the drive itself that may not be writing or reading the information sent by the pc to the port .You may need a new case with new electronics ( hard drive main board).
My computer won't recognize my
if your computer came with a motherboard disc the drivers could be on it click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working: ports(com&lpt)right click update driver" sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable, just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated hope this helps
Not recognising my hard drive on laptop
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
3/11/2013 7:52:12 AM •
Hitachi...
Answered
on Mar 11, 2013
Hitachi 50hyt62u H
can I add a removable drive as I have a slot in Back for one, and if so where do I get one
You should be able to buy an external USB drive (or thumb drive) at any electronics store.
You can connect a USB hard disk drive or USB
memory stick to your TV by using the USB inputs of
the TV. This feature allows you to play files stored in
a USB drive. 2.5" and 3.5" inch (hdd with external
power supply) external hard disk drives are supported.
IMPORTANT! You should back up your files before
making any connections to the TV set in order to
avoid any possible data loss. Manufacturer will not
be responsible for any file damage or data loss. It is
possible that certain types of USB devices (e.g. MP3
Players) or USB hard disk drives/memory sticks may
not be compatible with this TV.
Quickly plugging and unplugging USB devices, is a
very hazardous operation. Do not repeatedly quickly
plug and unplug the drive. This may cause physical
damage to the USB player and USB device itself. Do
not pull out USB module while playing a file.
Media Browser Menu
You can play photo, music, and movie files stored
on a USB disk by connecting it to your TV and using
the Media Browser screen. To do this, perform the
following: Connect a USB disk to one of the USB
inputs located on the side of the TV.
You can connect two USB devices to your TV. If both
USB devices include music, picture or video files, USB
selection OSD will be displayed on the screen. The
first USB device connected to the TV will be named
as USB Drive1. Select a device by using up or down arrows
and press OK
11/30/2019 1:10:18 PM •
Hitachi...
Answered
on Nov 30, 2019
