20 Most Recent Lenoxx Electronics CDR-190 Clock Radio Questions & Answers
How do I set the
http://www.retrevo.com/search?q=Lenoxx+Electronics+CDR-190
Page 1 and 8
Basically, hold the time button and adjust the hour and minute; hold the alarm button and adjust the hour and minute using the buttons.
10/29/2018 6:29:41 AM • Lenoxx... • Answered on Oct 29, 2018
How do I set the alarms -- I've lost my manual
The manual:
http://www.retrevo.com/support/Lenoxx-CDR-190-Clock-Radios-manual/id/22975ci174/t/2/
Hold the Time Button down,
and press the Hour Button,
until the right hour time shows
in the display.
and press the Minute Button
until the right minute time
shows in the display.
10/29/2018 6:29:29 AM • Lenoxx... • Answered on Oct 29, 2018
Hi . My clock radio clock continuously displays
Likely a bad backup battery inside the clock, or a capacitor that is leaking a charge.
11/17/2017 7:05:35 PM • Lenoxx... • Answered on Nov 17, 2017
0answers
How to set time on
Be the first to answer 8/18/2010 2:56:43 AM • Lenoxx... • Posted on Aug 18, 2010Be the first to answer
Need help
their is nothing you can do yourself to repair this as it needs a new laser unit but the only thing you can do is take it to tv repair shop and they will fit a new one and get it recalibrated for sorry i couldnt offer you any more help................................
11/29/2007 9:56:33 PM • Lenoxx... • Answered on Nov 29, 2007
0answers
Lenoxx manuals
Be the first to answer 3/10/2014 4:14:24 AM • Lenoxx... • Posted on Mar 10, 2014Be the first to answer
0answers
Parts manuals
Be the first to answer 1/13/2014 10:17:29 PM • Lenoxx... • Posted on Jan 13, 2014Be the first to answer
The cd player do not spin it comes on then go off
HelloThe sled motor of your player is not working. This is the motor that spins the disc inside as soon as it has been loaded. But to spin disc, the disc must be loaded properly into the loading mechanism. Just check the loading belt that attached with loading motor and loading gear set for any loose, which may cause improper disc loading. Replace it first. If it does not help you, check the voltage at the seled motor terminals. There must be a voltage [4.5VDC approx:]. If the voltage is there and still the sled motor does nor work, replace it. If voltage is not there, the fault is with the loading IC which is soldered to the main board of the device. OK>
1/5/2012 5:33:33 PM • Lenoxx... • Answered on Jan 05, 2012
0answers
No shuffle on model MP3-8700S
if the problem came from the factory it may be unavailable for the model ...but also can be just a software issue ..and updating the firmware can fix it ..Remember that updating firmware is a 2 way street ..and can cause good ..and loose some functions in the same time ..so ..think twice before proceed with it ..If it works good..I would not make it unless is a have to do it matter ..
The firmware can be downloaded from the support site of the manufacturer..
1/20/2011 4:50:36 AM • Lenoxx... • Answered on Jan 20, 2011
I have a model CD-102
I will advice you check either of any of this two sites amazon.com or ebay.com to get the replacement part you need for your device.
Take care.
9/4/2010 8:07:09 PM • Lenoxx... • Answered on Sep 04, 2010
Lenoxx Electronics CDR-190 Clock Radio Logo
Popular Tags
12 questions posted
Top Lenoxx Electronics Audio Players & Recorders Experts
Marvin
Marvin
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lenoxx Electronics Audio Players & Recorders
Most Popular Question
need help
  • Audio Players & Recorders
