20 Most Recent
Coby PC Netbook 1ea Questions & Answers
System restore
Most likely that would either be a failing boot device or the system is trying to boot to another connected device. Be sure there is nothing else connected to the system other than the power cord.
Need a current password
A professional repair shop can bypass the password. All you have to do is PROVE you own the laptop.
Enable wifi connection notebook
notebooks use different methods of turning on wifi. Some use a manual switch while others use a series of keyboard, for example, Fn+F2, check your manual for instuctions foryour brand pc
How Do I Connect To The Damn Inernet!!
There are many ways of connecting to internet.. You can connect it via Wired Network or Wireless Network.Can you tell me more about the network at your end, is it Wired or Wireless? Also, are you running a desktop or a laptop?Please let me know as this will help in narrowing down the issue.
Factory restore
restart the laptop and HOLDGIN the key fn+f1 or f2 depend of your model or mark. and go to factory restore.God bless you
I forgot my password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
http://www.hirensbootcd.net/ http://67.20.82.163/
Lines in the screen of my netbook
While this could be a connection problem, either a loose connection or a faulty video connection cable, more than likely it's the LCD that has the problem. It's hard to rule out a video connector cable, but I really wouldn't
suspect that unless the unit has gotten wet, or if the cable has been
pulled on, etcIf your netbook has an external VGA video connection, try connecting it to a different monitor. Obviously, if it works there, it's not a fault of the video system, but the panel itself.. If that is the case, I don't think it can be repaired, only replaced. If yours is still under warranty (1 year for most) you can contact Coby for repair information. Otherwise, the specific part number for your LCD is on the back of the unit. You can also search by your specific model #, but there may be more than 1 part # in your series of netbook.
Certain keys on my key
Replace the keyboard that most generally means liquid has been spilled on it at 1 time. They run about $20 online. You can try an external USB keyboard to verify thats what it is b4 you order a new 1.
