20 Most Recent Vivitek D530 Projector Questions & Answers
Hello
Check the Projection setting on the Installation I menu of the OSD
Vivitek D530... | Answered on Feb 12, 2012
hi,
check the power cable first. also check is there is power on the wall out let to which the projector is connected. if all ok then the projectors smps power supply may be faulty. for testing the same u have to open the projector. fist check the input fuse. if fond faulty, do not insert a new one immediately. check is there is any component fault in the smps. only after insert the fuse.
ok
Vivitek D530... | Answered on Dec 29, 2010
so long as the data disc has not curupted any other files a replacement should do ok
Yes, unfortunately the DMD chip has gone bad and will require to be replaced.
Vivitek Office... | Answered on Sep 25, 2015
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Vivitek Office... | Answered on Oct 12, 2014
Vivitek D530 Projector Logo
7 questions posted
Top Vivitek Office Equipment & Supplies Experts
Lawrence Oravetz
Tom Chichester
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Vivitek Office Equipment & Supplies
Most Popular Question
upside down picture vivitek d530
  • Office Equipment & Supplies
